sgilbert Posted December 27, 2023 Share Posted December 27, 2023 Looking for feedback and advice. I got out of riding a few years back but the bug is back. My last bike was a 2004 1150RT and will be looking for another RT. I don't want to go deep into cost at first and have found bikes in the price range in the 2008 to 2012 years, 45k or less and in good condition BUT have been greeting steered away from the pre-2010's but can't find any info here on why? Would I go wrong with either if the best bike is older than a 2009? Thanks Link to comment
dirtrider Posted December 27, 2023 Share Posted December 27, 2023 2 hours ago, sgilbert said: Looking for feedback and advice. I got out of riding a few years back but the bug is back. My last bike was a 2004 1150RT and will be looking for another RT. I don't want to go deep into cost at first and have found bikes in the price range in the 2008 to 2012 years, 45k or less and in good condition BUT have been greeting steered away from the pre-2010's but can't find any info here on why? Would I go wrong with either if the best bike is older than a 2009? Thanks Morning sgilbert When looking at pre 2010 1200RT motorcycles the later the better. With 2009 probably being the best, late 2008 being very close, early 2008 being pretty darn good. If possible try to eliminate the 2005 & 2006, with 2007 being better than the 2005/2006 but still lacking some of the better things of the 2008/2009. This isn't 100% as there are some fine 2005/2006 1200RTs and some 2008/2009 that had issues. But as rule the later the better in the 1200 hexhead model. The 1200 hexhead did have a few issues all the way through the model run with the fuel gauge fuel strip failing being the most prevalent. Not only do did a number of 1200RTs have failing fuel strips but with some it kept returning. There is a newer (supposedly updated) fuel strip available but I'm not sure if this a permanent fix or just a hope. The other thing that plagued some later 1200RTs was sticking brushes in the ABS servo motor. It's kind of a big pain to repair yourself & very expensive if having it repaired by a shop. (this only effected the 1200 hexhead bikes with IABS gen 2 (non wizzy) braking systems. Otherwise a few recalls for things like brake lines, rear wheel flange cracking (replaced with steel under a recall), cracking in the fuel pump flange (covered under a recall & a longer warranty). My suggestion is to read a number of older threads in the hexhead section on this web site as most issues have been covered a number of time over the years. The 2008/2009 1200RT was (still is) a great motorcycle but like most BMW motorcycles it's far from perfect. The 2011 up 1200 camhead is probably a little better as far as inherent issues go. The 2010 camhead still had that darn fuel strip. Link to comment
TEWKS Posted December 27, 2023 Share Posted December 27, 2023 What is your price range? Link to comment
sgilbert Posted December 27, 2023 Author Share Posted December 27, 2023 Thanks for the info.. I hope to keep it in the 5-6k range seeing I have been out of it and want to make sure that I still love riding as much as I did. Seeing that it is a few months before the riding season I may extend that if needed depending on what I put in the bike fund as a down payment. If I look at 2012 and 2013's with 40-50k would that milage scare anyone.. here is one possible https://www.kissellmotorsports.com/default.asp?page=xPreOwnedInventoryDetail&id=14753385&p=3&make=bmw&s=(Sort By)&d=D&fr=xPreOwnedInventory guess I need a new bike to update my pic from the 04 1 Link to comment
jjpen Posted December 27, 2023 Share Posted December 27, 2023 rtron makes it run better but that is my story and I am sticking to it. Link to comment
jjpen Posted December 27, 2023 Share Posted December 27, 2023 I do not do much posting so I lost all that I had written before in the previous post. I am not in the mood to retype it all. Link to comment
sgilbert Posted December 27, 2023 Author Share Posted December 27, 2023 I still have it and using it for my decision and really based on that heading towards the 2010+ with that how would you rate the bike in the link above a solid deal. 2011 so falls in your range and it is about 4 hrs away but may head down this weekend to look at it but being an 11 it gets away from that "darn fuel strip" Link to comment
dirtrider Posted December 27, 2023 Share Posted December 27, 2023 25 minutes ago, sgilbert said: I still have it and using it for my decision and really based on that heading towards the 2010+ with that how would you rate the bike in the link above a solid deal. 2011 so falls in your range and it is about 4 hrs away but may head down this weekend to look at it but being an 11 it gets away from that "darn fuel strip" Morning sgilbert I can't open the link to anything useful, all I get is your inbox. I'm not going to dig around in someone's inbox. Try to get the motorcycle info as a direct link, or at least get a picture of it on your computer or phone in .JPG form then attach it to your post here. Link to comment
sgilbert Posted December 27, 2023 Author Share Posted December 27, 2023 wow sorry update that link to this https://www.kissellmotorsports.com/default.asp?page=xPreOwnedInventoryDetail&id=14753385&p=3&make=bmw&s=(Sort By)&d=D&fr=xPreOwnedInventory Link to comment
dirtrider Posted December 27, 2023 Share Posted December 27, 2023 48 minutes ago, sgilbert said: I still have it and using it for my decision and really based on that heading towards the 2010+ with that how would you rate the bike in the link above a solid deal. 2011 so falls in your range and it is about 4 hrs away but may head down this weekend to look at it but being an 11 it gets away from that "darn fuel strip" Morning sgilbert Some obvious boot scuffs, L/H side was down at standstill at least once, but looks decent from the pictures (but keep in mind that most dealers are masters of putting a glow on a pig. Not saying they did just saying that they can easily do that. Price seems decent (especially with a new front tire & service). My number one recommendation is: if possible try to take a mechanically competent current 1200 rider with you to look at it if possible. A second set of eyes is usually a good thing & a non buyer usually is not dazzled with the prospect of owning that motorcycle like you will probably be. From what I can see in the pictures (pictures can hide things) & the price, it looks like it would be worth the drive to look at it as long as the scuffs won't bother you as repairing those cosmetic things cost way more than you think it would. Look closely at the rear wheel, I see some stains on the rim , most likely brake dust & water that dripped off after washing it. But if those stains are greasy feeling or oily feeling, or look like from a final drive leak, then don't buy it without the dealer repairing it first. Same with rear of engine front of catalytic converter, look for signs of oil seepage and/or old seepage stains. Also look at the brake pads, if they look well worn then have dealer replace before buying. The dealer can do that fairly cheaply but once you own it those same brake pads/replacement will be expensive. Also ask if they will give you a short term warranty, you won't get much but even a 30 day can give you options on things that you find after buying it. You might even insist on a 30 day before you will buy it. Might work & might not but sure worth a try. 1 Link to comment
sgilbert Posted December 27, 2023 Author Share Posted December 27, 2023 awesome thanks for the feedback and will be printing this off and taking it with me... Link to comment
sgilbert Posted December 27, 2023 Author Share Posted December 27, 2023 the link to the 2013 https://www.bobsmotorcycles.com/Pre-owned-Inventory-2013-BMW-Motorcycle-Scooter-R-1200-RT-Silver-Bob-s-Motorcycles-14809716?ref=list but I think the price may be high but it has more options Link to comment
dirtrider Posted December 27, 2023 Share Posted December 27, 2023 12 minutes ago, sgilbert said: the link to the 2013 https://www.bobsmotorcycles.com/Pre-owned-Inventory-2013-BMW-Motorcycle-Scooter-R-1200-RT-Silver-Bob-s-Motorcycles-14809716?ref=list but I think the price may be high but it has more options Afternoon sgilbert On the first one, I went back & listened to the walkaround again, it mentions that it has no rear ESA. That could be a good thing as ESA repair or replacement is expensive. If you mainly ride without a passenger or heavy camping gear then you probably won't adjust it much anyhow. If you ride with & without a passenger regularly then having ESA is a pretty good asset. On the second bike that you linked to, I can't tell lot from the pictures so you either need better resolution pictures or need to look at it in person. On face value it looks decent but on-line pictures can hide a lot of things. Do they have a service history on that second motorcycle? Link to comment
sgilbert Posted December 27, 2023 Author Share Posted December 27, 2023 waiting for the reply about the service history so hopefully can update that soon.. maybe save up more, go to National Powersports and but the 1600,, I wish but one can dream https://www.nationalpowersports.net/itemdetails.cshtml?loc=inv&itemid=59584 Link to comment
sgilbert Posted December 27, 2023 Author Share Posted December 27, 2023 starting to think I should have grabbed that great condition 2002 LT for under $3 just to see if I love to ride again.. cheap, gets be back on a bike and if I decide it is a no I am not out much Link to comment
TEWKS Posted December 27, 2023 Share Posted December 27, 2023 59 minutes ago, sgilbert said: starting to think I should have grabbed that great condition 2002 LT for under $3 They pop up time to time on CL. There was a 2012 K 16 GTL on there for 6K but I see the ad expired. Link to comment
TEWKS Posted December 27, 2023 Share Posted December 27, 2023 Here’s a good bike to see if motorcycling still “gets your motor running” It should be worth pretty much the same five years down the road. Link to comment
sgilbert Posted December 27, 2023 Author Share Posted December 27, 2023 I'll dig into it thanks.. may not be a bad little beater if I end up going tourer either 1 Link to comment
6speedTi Posted December 27, 2023 Share Posted December 27, 2023 4 hours ago, sgilbert said: the link to the 2013 https://www.bobsmotorcycles.com/Pre-owned-Inventory-2013-BMW-Motorcycle-Scooter-R-1200-RT-Silver-Bob-s-Motorcycles-14809716?ref=list but I think the price may be high but it has more options This is a nice loaded RT. From the photos I see it has TPMS, ASC, ESA, radio and heated seats. My 2012 is same color and options. Fully loaded. I'm not sure about the price if it's high or average. Mileage is low only to compare it with my identical 2012 with 104,000 miles. You need to inspect it, test ride it and check all the maintenance records. Follow Dirt Riders lead on what to look for and what to negotiate for based on what you find. Definitely a nice low mileage RT. Good luck. Link to comment
sgilbert Posted December 27, 2023 Author Share Posted December 27, 2023 Thanks and I am still waiting for a reply about having the service history. I printed off DirtRiders lead and will taking it with me so I don't forget anything. Why can't BMW be like Harley and make stuff I don't love.. so far I loved the 02 1200 LT I looked at, the RT's and then I sat on a 1600 GTL and I never wanted to get off... are there pills to help with these issues? Link to comment
Hati Posted December 28, 2023 Share Posted December 28, 2023 7 hours ago, sgilbert said: are there pills to help with these issues? LOL... Yeah, rather large pill. Comes on two wheels and you can even sit on it ;) Link to comment
Motorhead1977 Posted December 28, 2023 Share Posted December 28, 2023 16 hours ago, TEWKS said: Here’s a good bike to see if motorcycling still “gets your motor running” It should be worth pretty much the same five years down the road. That's about 10 miles from me if you want to have someone see it in person. LMK 1 Link to comment
TEWKS Posted December 28, 2023 Share Posted December 28, 2023 11 minutes ago, Motorhead1977 said: That's about 10 miles from me if you want to have someone see it in person. LMK @sgilbert If he doesn’t see your generous offer! Link to comment
sgilbert Posted December 28, 2023 Author Share Posted December 28, 2023 GM and thank you for that offer and I may take you up on it. I'm going to look at a low mile K1200LT on Sat that I was offered to me at a great which is in awesome condition. May get that to get back on the road and then next year seriously take a look at the 1600. If the LT ends up as a no go I just may ask if you would take a look at that and then if I get it take you out for a beer and a bite for doing so. 1 Link to comment
profbodryak Posted December 30, 2023 Share Posted December 30, 2023 Had a 2005 RT at one point that I purchased in 2015 which, except the fuel strip issue that is a recall, hasn't had any issues with it in a little less than 1.5 years. At one point the shifter started sticking but the mounting hole just needed cleaning from the road gunk. Link to comment
