simonclark Posted December 8, 2023 Share Posted December 8, 2023 Hi! Fitting new fors seals to 2001 R1150RT. Which way up do they go? Visible spring to the top? Link to comment
9Mary7 Posted December 8, 2023 Share Posted December 8, 2023 Same orientation as the ones you removed.......usually that means the part numbers are visible on the top. Link to comment
simonclark Posted December 8, 2023 Author Share Posted December 8, 2023 Didn't think to check when taking them out. I'll check for part number. Thank you Link to comment
Michaelr11 Posted December 9, 2023 Share Posted December 9, 2023 Look carefully at the inside of the seal. The side that has a double lip faces the oil. That should be the side with the visible spring, but the double lip is the criteria that matters. Link to comment
duckhawk64 Posted December 9, 2023 Share Posted December 9, 2023 2 hours ago, Michaelr11 said: Look carefully at the inside of the seal. The side that has a double lip faces the oil. That should be the side with the visible spring, but the double lip is the criteria that matters. That's what I've always done. Spring towards the oil, or down. Link to comment
