bruce2000ltc Posted November 29, 2023 Share Posted November 29, 2023 I saw this oil change trick on YouTube where you punch a hole in a car oil filter to let it drain before you remove it. Looked like a great idea so I thought I’d try it on my ‘13RT. Warmed up the bike, put the oil pan under the motor and using a small punch and hammer I tapped the punch into the oil filter. Pulled the punch out and here came the oil. I went to the other side of the bike and removed the oil drain plug. After the oil filter stopped draining I wiped the bottom of the filter and loosened it with my wrench. I loosened the filter the rest of the way by hand and a little more oil came out the hole I’d punched as air got in and broke the vacuum. Removed the oil filter, installed the new filter and the oil drain plug. This was easily the cleanest and least messy oil change I’ve ever done on the RT. No oil drenched filter or oil splashed on the engine around the filter area to clean up. Just wipe the the sealing surface on the engine clean, oil the filter gasket and spin on the filter—done. I wish I’d known about this trick sooner… it sure would of saved a lot of time. I’m going to use this trick on all my cars from now on, too. 1 Link to comment
Shelterwoods Posted November 29, 2023 Share Posted November 29, 2023 Nice. Thank you. Link to comment
John Ranalletta Posted November 29, 2023 Share Posted November 29, 2023 47 minutes ago, bruce2000ltc said: I saw this oil change trick on YouTube where you punch a hole in a car oil filter to let it drain before you remove it. Looked like a great idea so I thought I’d try it on my ‘13RT. Warmed up the bike, put the oil pan under the motor and using a small punch and hammer I tapped the punch into the oil filter. Pulled the punch out and here came the oil. I went to the other side of the bike and removed the oil drain plug. After the oil filter stopped draining I wiped the bottom of the filter and loosened it with my wrench. I loosened the filter the rest of the way by hand and a little more oil came out the hole I’d punched as air got in and broke the vacuum. Removed the oil filter, installed the new filter and the oil drain plug. This was easily the cleanest and least messy oil change I’ve ever done on the RT. No oil drenched filter or oil splashed on the engine around the filter area to clean up. Just wipe the the sealing surface on the engine clean, oil the filter gasket and spin on the filter—done. I wish I’d known about this trick sooner… it sure would of saved a lot of time. I’m going to use this trick on all my cars from now on, too. I saw this recently as well and I also remember back to when I worked in a service station to pay tuition. We couldn't remove the filter and had to chisel it off (still have scars). So, unscrew the filter a tad before drilling. Link to comment
VaR1200RT Posted November 29, 2023 Share Posted November 29, 2023 I may try this on the next change Link to comment
AviP Posted November 29, 2023 Share Posted November 29, 2023 Interesting. Will try it out at the next oil change. Link to comment
wbw6cos Posted November 29, 2023 Share Posted November 29, 2023 I know a certified meticulous maintenance guy use a drill to pierce the filter on a Wethead bike. Make sure the hole is drilled where it needs to be after the slight rotation of said filter. Just sayin' 1 Link to comment
Skywagon Posted November 29, 2023 Share Posted November 29, 2023 I don’t drill mine because I open them up and check for metal each time. I have an oil filter cutter that does not put metal flakes in the filter. Makes a bit of a mess but if something is making metal I’ll know. I like the solo cup idea. Will try it next time. I hope it doesn’t ruin the taste of my beer 🍺 I don’t cut open filters on cars though. 1 Link to comment
6speedTi Posted November 29, 2023 Share Posted November 29, 2023 Wow! I find that to be a messy and more laborious maintenance procedure. If we are talking about a camhead engine I can't see taking that route. I simply use a oil filter wrench and a breaker bar or a ratchet. Placing a drain bucket on the ground I just loosen the oil filter until I see oil draining from the filter itself. Then go back and screw it off by hand after it drains out. I hate to ask how one installs the new filter. 🙄 1 Link to comment
szurszewski Posted November 30, 2023 Share Posted November 30, 2023 23 hours ago, John Ranalletta said: I saw this recently as well and I also remember back to when I worked in a service station to pay tuition. We couldn't remove the filter and had to chisel it off (still have scars). So, unscrew the filter a tad before drilling. I was going to suggest the same - that way you won't end up with a bike where you can't remove the filter or ride it to a shop. Plus, that way you don't have to get any oil at all on your filter wrench as you can just remove the filter by hand once it's drained. But, after a few punch drains, I switched to the solo cup method below. (BMW spec oils are fully compatible with darker things like porter or, better, schwarzbiers.) 21 hours ago, Rougarou said: 17 hours ago, 6speedTi said: Wow! I find that to be a messy and more laborious maintenance procedure. If we are talking about a camhead engine I can't see taking that route. I simply use a oil filter wrench and a breaker bar or a ratchet. Placing a drain bucket on the ground I just loosen the oil filter until I see oil draining from the filter itself. Then go back and screw it off by hand after it drains out. I hate to ask how one installs the new filter. 🙄 The methods above will let you drain the oil without getting any on your hands at all and really don't take more time. But, as always, getting the old oil out and the new oil in by whatever means you like is way better than running out or running dirty oil :) 1 Link to comment
6speedTi Posted November 30, 2023 Share Posted November 30, 2023 4 hours ago, szurszewski said: I was going to suggest the same - that way you won't end up with a bike where you can't remove the filter or ride it to a shop. Plus, that way you don't have to get any oil at all on your filter wrench as you can just remove the filter by hand once it's drained. But, after a few punch drains, I switched to the solo cup method below. (BMW spec oils are fully compatible with darker things like porter or, better, schwarzbiers.) The methods above will let you drain the oil without getting any on your hands at all and really don't take more time. But, as always, getting the old oil out and the new oil in by whatever means you like is way better than running out or running dirty oil :) I don't get oil on my wrench or hands. I just loosen the oil filter and rotate it until I see oil run down the sides. Then go and drain the crankcase. When I go back the oil filter has stopped draining. Very simple and easy. I just cringe when I think of people ramming a screw driver through an oil filter for no useful purpose other than one that is jammed up tight. This happens when someone installs an oil filter using gorilla strength torque values. Whatever works best for the individual is fine. Not me though. 2 Link to comment
6speedTi Posted December 2, 2023 Share Posted December 2, 2023 If you find yourself not having the proper tool to do the job I'd rather use a screw driver for this alternate use. Very clever. 👍 1 Link to comment
6speedTi Posted December 2, 2023 Share Posted December 2, 2023 Just incase no one has thought ahead what could happen. Self explanatory. 😬 1 Link to comment
