Rob Nowell Posted November 26, 2023 Share Posted November 26, 2023 I just switched out my rear tire. Removing the muffler allows better access to the lug bolts, and I've never had a problem with removing/reinstalling that...until now. That damn thing does NOT want to go back on! It just wont align with the hanger bracket screw hole. Any ideas? I'd thought about a bit of WD-40, but figured that would stink like hell when it heats up. Link to comment
Hosstage Posted November 26, 2023 Share Posted November 26, 2023 The WD-40 will dry and leave little residue, any smell will be minimal. 1 Link to comment
Bernie Posted November 26, 2023 Share Posted November 26, 2023 Loosen the clamp until you have the bolt lined up with the hanger. You may just have to wiggle it a little back and forth till it aligns. 1 1 Link to comment
Rob Nowell Posted November 27, 2023 Author Share Posted November 27, 2023 I don't remember the gap being there. Link to comment
Bernie Posted November 27, 2023 Share Posted November 27, 2023 You need to rotate the muffler a little bit more. Loosen the front clamp and remove the rear bolt and wiggle it up and down while turning it counterclockwise. The bracket on the canister should be touching the mounting bracket. 36 minutes ago, Rob Nowell said: I don't remember the gap being there. 1 Link to comment
Cap Posted November 28, 2023 Share Posted November 28, 2023 1 hour ago, Rob Nowell said: I don't remember the gap being there. I think the nut goes on the back side.... Link to comment
Bernie Posted November 28, 2023 Share Posted November 28, 2023 3 minutes ago, Cap said: I think the nut goes on the back side.... Yes, of course. I didn’t notice it in the picture. Link to comment
Rob Nowell Posted November 28, 2023 Author Share Posted November 28, 2023 50 minutes ago, Bernie said: You need to rotate the muffler a little bit more. Loosen the front clamp and remove the rear bolt and wiggle it up and down while turning it counterclockwise. The bracket on the canister should be touching the mounting bracket. It just won't go. Link to comment
Bernie Posted November 28, 2023 Share Posted November 28, 2023 Take it back of and start over. And when you start to again it with the pipe by the center stand, make sure the nut on the bracket of the canister is on the wheel side of the mounting bracket. It is explained in your manual for your bike, including pictures. 1 1 1 Link to comment
lkraus Posted November 28, 2023 Share Posted November 28, 2023 12 hours ago, Rob Nowell said: It just won't go. Take it off and start over. Spread the end of the pipe a little bit(~1mm) so it slides/rotates easier. Clean the surfaces at the joint and apply anti-seize, it makes it easier to rotate the pipe and to remove it next time. Slide the pipe on and leave the clamp completely loose. Install the hanger bolt halfway while everything is loose, tighten the clamp, and then the bolt. 1 1 Link to comment
Aussie Mark Posted November 28, 2023 Share Posted November 28, 2023 Looks like you're very close.. I agree with the the above suggestions, start again and a little lube (Optimoly TA 18 21 9 062 599 or Equiv, Honda M77). Don't forget the alignment of the clamp underneath and 22Nm for the clamp nut. 19Nm for the rear. Link to comment
Cap Posted November 28, 2023 Share Posted November 28, 2023 21 hours ago, Rob Nowell said: It just won't go. I thought I explained it above.... But you have the exhaust can hanger on the front side of the frame mounting point. That is incorrect. You need to remove the exhaust from the header and rotate the exhaust can towards the tire at the top, such that the hanger slips in behind the frame. Then, insert the bolt through the fancy washer, then through the frame, and thread it into that nut. I can imagine that you might have some difficulty getting it to line up nicely now that you have bent the hanger somewhat. But, if you get it in place and tighten it up, it should straighten the hanger. Cap Link to comment
Rougarou Posted November 29, 2023 Share Posted November 29, 2023 If what they explained doesn't work: 2 2 2 Link to comment
Aussie Mark Posted November 29, 2023 Share Posted November 29, 2023 As Cap has described. 2 Link to comment
Rob Nowell Posted November 29, 2023 Author Share Posted November 29, 2023 Holy crap, Rob! 🙄🤨 1 1 Link to comment
