Aussie Mark Posted November 16 Share Posted November 16 For those that may be using the Knight Design lowering pegs, would you be able to provide a measurement from the center connector pin to the outboard edge of the Peg. Also what model of peg you are using. Metal or metal with rubber pad? Being vertically challenged and and a dodgy knee, I'm trying to get a lowering peg that does not increase the distance from the bike to the end of the peg, as some designs do. KR, Mark Link to comment
Cap Posted November 16 Share Posted November 16 I'm having trouble visualizing your desired measure. Could you post a pic of a footpeg with a scale laid on the measure you want? I use Suburban Machinery footpeg lowering blocks with the stock pegs. They move the pegs down and slightly forward... but not outward. Is that what you want? Cap Link to comment
Aussie Mark Posted November 16 Author Share Posted November 16 Cap, This is the dimension I'm after. The current Wunderlich design positions the peg further from the bike and while I like the height, I find it forces my leg a little wide when I try and put my feet down. Mark Link to comment
realshelby Posted November 16 Share Posted November 16 I have been running and recommending Knight Design lowered footpegs for many years. I don't have the measurement you are asking for at hand. But I do know it is not sticking out further than the stock footpeg. Unlike Suburban Machinery, Illium, Wunderlich, these pegs simply replace the oem BMW peg at the pivot point. Unlike the other brands they do not use a bracket to lower the peg, which also moves the peg outward a bit. The Knight Design pegs give about the same cornering clearance as an oem with the peg feelers on the ends. They do this by eliminating the rubber portion, and by using a high strength CNC machined footpeg that isn't too thick. I was not aware they even offered a rubber option? My initial concern was my foot sitting on a bare aluminum surface would transmit vibrations. What I found was....that I really cannot tell any vibrations come through. I always wear boots. One positive side effect is that your boot stays where you put it on these. Wet or dry it is MUCH better than a rubber peg. They look like they are oem installed. They cost a LOT less than other choices and work better based on my experience. As with ANY lowered peg setup, you will have to adjust your shifter height ( easy) and your brake pedal height ( not so easy but doable with no new parts needed). 1 Link to comment
JC120 Posted November 16 Share Posted November 16 Just measured mine and came up with 4 5/8" I also don't have the rubber on and haven't noticed any vibration JC120 1 Link to comment
alegerlotz Posted November 16 Share Posted November 16 2 hours ago, JC120 said: Just measured mine and came up with 4 5/8" I also don't have the rubber on and haven't noticed any vibration JC120 I just measured mine as well to see if they are the same; they are. 4 5/8" (12 cm). I noticed the lack of rubber during my first ride and pretty much from then on, its just how the RT feels. My R Nine T still has the stock pegs with rubber and I don't feel any difference with respect to the pegs going from one bike to the other. 1 Link to comment
Aussie Mark Posted November 18 Author Share Posted November 18 Thanks all for the information and measurements.. I'll do some comparison work on the RT and determine what the delta is. KR, Mark Link to comment
hound Posted November 21 Share Posted November 21 On 11/16/2023 at 7:53 AM, realshelby said: I have been running and recommending Knight Design lowered footpegs for many years. I don't have the measurement you are asking for at hand. But I do know it is not sticking out further than the stock footpeg. Unlike Suburban Machinery, Illium, Wunderlich, these pegs simply replace the oem BMW peg at the pivot point. Unlike the other brands they do not use a bracket to lower the peg, which also moves the peg outward a bit. The Knight Design pegs give about the same cornering clearance as an oem with the peg feelers on the ends. They do this by eliminating the rubber portion, and by using a high strength CNC machined footpeg that isn't too thick. I was not aware they even offered a rubber option? My initial concern was my foot sitting on a bare aluminum surface would transmit vibrations. What I found was....that I really cannot tell any vibrations come through. I always wear boots. One positive side effect is that your boot stays where you put it on these. Wet or dry it is MUCH better than a rubber peg. They look like they are oem installed. They cost a LOT less than other choices and work better based on my experience. As with ANY lowered peg setup, you will have to adjust your shifter height ( easy) and your brake pedal height ( not so easy but doable with no new parts needed). Can you verify if the Knight Design fit the 21+ RT? I emailed them this question but have not heard back. Link to comment
realshelby Posted November 21 Share Posted November 21 I don't own a 2021+ RT. But I have had talked with many owners that call about my Quiet Ride windshields and told them about the Knight Design pegs. No, the website does not show the newer year models as a fitment. But I know some of the owners I have talked with have ordered the Knight Design pegs that ARE listed for the previous generation RT. Never heard of a problem with them. I do not think there is a difference at all in the factory footpeg design from 2014 to current production based on pictures of them. 1 Link to comment
strataj Posted November 21 Share Posted November 21 8 minutes ago, realshelby said: I don't own a 2021+ RT. But I have had talked with many owners that call about my Quiet Ride windshields and told them about the Knight Design pegs. No, the website does not show the newer year models as a fitment. But I know some of the owners I have talked with have ordered the Knight Design pegs that ARE listed for the previous generation RT. Never heard of a problem with them. I do not think there is a difference at all in the factory footpeg design from 2014 to current production based on pictures of them. I don't have the Knight Design pegs, I have the Suburban Machinery ones, I moved them a 14R1200RT to a 22R1250RT without any problem. I also move the Iluim brake pedal. 1 1 Link to comment
MikeB60 Posted November 21 Share Posted November 21 10 hours ago, hound said: Can you verify if the Knight Design fit the 21+ RT? I emailed them this question but have not heard back. I just ordered a set for my 22 RT. The stock foot peg for the 1250RTs has the same part number as the WC 1200RTs no reason why they shouldn't fit. 1 Link to comment
