Dave P Posted November 14 Share Posted November 14 2007 R1200RT, my bike has the amber plastic front signal covers, I think the clear ones look cool, thought maybe Id switch them out. Is it this simple or are the sockets (that hold the bulbs) different? Cause I'd need to get amber bulbs. Thanks, Dave Link to comment
dirtrider Posted November 14 Share Posted November 14 1 hour ago, Dave P said: 2007 R1200RT, my bike has the amber plastic front signal covers, I think the clear ones look cool, thought maybe Id switch them out. Is it this simple or are the sockets (that hold the bulbs) different? Cause I'd need to get amber bulbs. Thanks, Dave Afternoon Dave Sockets are the same but you need new bulbs (amber bulbs) as the clear bulbs that you have now won't work with clear lens's. To be legal you need amber light emitting. Link to comment
Dave P Posted November 14 Author Share Posted November 14 Ok that's cool, easy for a change! D Link to comment
RadioFlyer Posted November 15 Share Posted November 15 7 hours ago, dirtrider said: Afternoon Dave Sockets are the same but you need new bulbs (amber bulbs) as the clear bulbs that you have now won't work with clear lens's. To be legal you need amber light emitting. Just wondering if you are certain about that as in my experience clear bulbs have a BA15S base whereas amber bulbs have a BAU15S base. The difference is in the clocking. Link to comment
dirtrider Posted November 15 Share Posted November 15 8 hours ago, RadioFlyer said: Just wondering if you are certain about that as in my experience clear bulbs have a BA15S base whereas amber bulbs have a BAU15S base. The difference is in the clocking. Morning RadioFlyer Now that you mention it, I'm not sure. And in looking at my parts manual the sockets ARE listed with different part numbers. So the clear bulb sockets are probably different. They do look the same at first glance. When the BMW 1200RT first came out I converted a couple of orange turn signal motorcycles to clear. BMW dealers used to offer a plug-in conversion kit to do that. It's been so long that can't remember but they were pretty well plug & play as they came with the orange bulbs/sockets already in place. Thanks for pointing this out as obviously I wasn't paying enough attention when I did the conversions. Link to comment
Dave P Posted November 15 Author Share Posted November 15 Yeah, I was originally thinking I could just switch out the lenses and bulbs, guess there's more to it than I thought. Still easy, just not as cheap. D Link to comment
DJDixon Posted November 15 Share Posted November 15 I just looked at the clear lights in the garage, the OEM clear light assemblies come with the clear lenses, the amber bulb and the bulb socket with two spade type connectors. You unplug the yellow lights (two wires) and then plug in the clear lights. No wiring changes needed. Link to comment
Dave P Posted November 18 Author Share Posted November 18 So I saw some bulbs at Menards the other night and the amber bulbs had the same base as the clear bulbs. Bought the amber bulbs and tried them on the bike. They fit, they worked! Think I'll buy some clear lenses over the winter. 1 Link to comment
Bike and ref Posted November 26 Share Posted November 26 Bought the clear lens off of amazon not OE. Right and left sockets are different as the direction they turn in to lock. Both lens fit the socket on the left side not the right. I was heading on a trip soon so I cut the plastic stop bar on the socket . Its been over a year and it never came loose or leaked water in to it. You may not experience this it's just my tale. I attached a photo, it's not the socket in question but you'ii get the idea. Al Link to comment
Dave P Posted November 27 Author Share Posted November 27 Bike- I'm not totally following you. Did you replace the lenses or the whole assembly? I was hoping to just replace the lenses and bulbs, not the whole assembly $$. Did you find lenses on Amazon? If so Id be interested in having that link. Dave Link to comment
Bike and ref Posted Sunday at 09:30 PM Share Posted Sunday at 09:30 PM https://www.amazon.com/XUEFURONG-Motorcycle-Indicator-Compatible-2005-2009/dp/B09HZMXVXQ?th=1 amazon, it's a assembly you can't just change lens it's glued together. Link to comment
Dave P Posted 19 hours ago Author Share Posted 19 hours ago Bike- so what you are saying is that if I purchase the set of clear lenses (clear and opaque assembly) on Amazon, one of the sockets will fit the other one wont. Is that correct? thought this would be easier than this. Link to comment
dirtrider Posted 7 hours ago Share Posted 7 hours ago 11 hours ago, Dave P said: thought this would be easier than this. Morning Dave If you use aftermarket products then you can end up with aftermarket issues with wire splicing concerns. If you use BMW OEM lenses/housings then they come with the proper sockets & bulbs. The OEM BMW sockets are a simple plug-in to the existing wires (the BMW sockets have standard spade terminals on them so a simple existing wire plug-in). Link to comment
