randy Posted November 14, 2023 Share Posted November 14, 2023 I have been looking for one of the new battery powered air pumps. Any real life usage/recommendations. I like the idea of an air pump not needing 12v supply. Again hoping someone had gone this route and can make a recommendation. this is for example only Amazon.com: Airmoto Tire Inflator Portable Air Compressor/Pump for Car Tires w/Digital Tire Pressure Gauge - Air Compressor (120 PSI) - Motorcycle, Electric Bike Pump and Bicycle Pump w/LED Light : Automotive Link to comment
szurszewski Posted November 15, 2023 Share Posted November 15, 2023 I like the idea of not having to connect it to the bike (and possibly to run the bike while inflating), but I wonder how long it will run on a charge - can I fill a tire from flat? More than one? I also like the idea, with a wired pump, it just lives on the bike - maybe for years at a time without being touched - and I never have to worry about it being charged. Curious to see if anyone has experience actually using one of these.... Link to comment
Michaelr11 Posted November 15, 2023 Share Posted November 15, 2023 Belt and suspenders….. I carry a 12 volt air pump, and I also have a few CO2 cartridges. The CO2 is there just in case the pump fails, which it hasn’t in the 15+ years it’s been living in the saddle bag. This summer, had to use the pump on the rear tire. Filled it up to 40 PSI in about 6-7 minutes. No issues with starting the bike again after the fill. Link to comment
lkraus Posted November 15, 2023 Share Posted November 15, 2023 The small battery powered pumps are probably good to carry on a bicycle, where there is no other power source. I feel the 12V source on my motorcycle is more reliable as long as I don't run out of gas. The 12-year-old Slime pump tucked into my RT's tail section doesn't care if I ignore it for several years, but I would surely forget to keep another battery charged. Batteries have a limited lifetime, which likely would mean replacing the entire pump. A 12V pump for the motorcycle and cars just makes more sense to me. Link to comment
Skywagon Posted November 15, 2023 Share Posted November 15, 2023 1 hour ago, lkraus said: The 12-year-old Slime pump tucked into my RT's tail section doesn't care if I ignore it for several years, but I would surely forget to keep another battery charged. ^^^^^This. I have a 12V slime in the bag. Only used it once in the 17 years I've owned it. I hate batteries. Link to comment
Red Posted November 15, 2023 Share Posted November 15, 2023 Ikraus, the plug in pump will work with the ignition on. It only needs lektrons. Doesn't care if the bike is running or not. But hey, w/o gas you're not going anywhere anyway I spoz. 1 Link to comment
