Tank Posted November 13, 2023 Share Posted November 13, 2023 trouble tonight... HELP please. 2020 GSA, seems I have locked my forks... keyless system Link to comment
John Ranalletta Posted November 13, 2023 Share Posted November 13, 2023 4 minutes ago, Tank said: trouble tonight... HELP please. 2020 GSA, seems I have locked my forks... keyless system I don't have personal experience, but an AI query offers this. Hope it works and good luck. To unlock the forks on a 2020 BMW GSA with a keyless system, you can follow these steps1: Turn the handlebars all the way to the left. Push and hold the ignition button until you hear a click1. This should unlock the forks. Link to comment
profbodryak Posted November 13, 2023 Share Posted November 13, 2023 Is there strain on the forks because you parked on an incline? If forks are locked, the first button push, should actuate the lock. Do you hear any sounds from the locking mechanism at all? Link to comment
Tank Posted November 13, 2023 Author Share Posted November 13, 2023 thanks John.... It won't release. I hear the click, but no luck Link to comment
Tank Posted November 13, 2023 Author Share Posted November 13, 2023 9 minutes ago, profbodryak said: Is there strain on the forks because you parked on an incline? If forks are locked, the first button push, should actuate the lock. Do you hear any sounds from the locking mechanism at all? bike is on flat ground , on center stand, I can hear the click to unlock the forks....... although I don't know if I am r RElocking or UNlocking at this pointjk Link to comment
profbodryak Posted November 13, 2023 Share Posted November 13, 2023 Try wiggling the fork as it tries to actuate. Link to comment
Tank Posted November 13, 2023 Author Share Posted November 13, 2023 No Joy, I was gentle with locking pin.... I am guessing that its a pin Link to comment
John Ranalletta Posted November 13, 2023 Share Posted November 13, 2023 FWIW. Maybe try a short tap instead of a longer one. From the riders manual Link to comment
profbodryak Posted November 13, 2023 Share Posted November 13, 2023 Probably a crappy advice but try hitting the fork right in the center with your palm several times. Who knows, maybe something got inside and stuck in there? Link to comment
Tank Posted November 13, 2023 Author Share Posted November 13, 2023 Not sure what exactly I have done , but the unlock noise was different and I now have a free fork unit . Many thanks for the input tonight. I have cancelled the trailer and Gary seemed happy also that he won't need to travel on a Monday morning 3 Link to comment
profbodryak Posted November 13, 2023 Share Posted November 13, 2023 We didn't do anything, you solved it all! Glad you got out of being stranded, Tank. 1 1 Link to comment
JCtx Posted November 13, 2023 Share Posted November 13, 2023 I also have a 2020, and to unlock the forks, you just quickly press the start/stop button (like turning ignition on), and forks immediately unlock (and ignition turns on as well). You only have to hold it down to LOCK it. So seems like you were locking it every time. By the way, I also thought I needed a long-press to unlock it, but glad I found out by accident that it unlocks with just touching the start/button to turn the ignition on. I was going to start the bike, and then unlock the forks, so glad I found out about how to unlock it the easy way. Ha ha. It was the first and only time I've used the lock. 1 Link to comment
