aternie Posted November 2, 2023 Share Posted November 2, 2023 I am hitting a wall trying to find a way to purchase the DIY cam chain tensioner. I have an order in with BMW N America and as you probably know, the ETA keeps shifting to the right . . .now first quarter 2024. Any suggestions? Ernie Link to comment
szurszewski Posted November 2, 2023 Share Posted November 2, 2023 30 minutes ago, aternie said: I am hitting a wall trying to find a way to purchase the DIY cam chain tensioner. I have an order in with BMW N America and as you probably know, the ETA keeps shifting to the right . . .now first quarter 2024. Any suggestions? Ernie You are not the only one - they seem to be very hard to get. We happen to have a guy here that's an option, but his availability is limited too and I don't know if he is open to selling individual bits. Here is a link to sets he had for sale recently: 2 Link to comment
aternie Posted November 3, 2023 Author Share Posted November 3, 2023 Thanks for the reply. I found the tensioner and sleeve at a dealer today. 1 Link to comment
szurszewski Posted November 3, 2023 Share Posted November 3, 2023 1 hour ago, aternie said: Thanks for the reply. I found the tensioner and sleeve at a dealer today. So you’re saying posting here magically solved your problem? That’s fantastic :) 1 Link to comment
BABABeemer Posted November 3, 2023 Share Posted November 3, 2023 I saw these manual chain tensioners for sale on a popular marketplace. I wonder if they would do the trick? $105 for a pair. I imagine only one would be required? Link to comment
aternie Posted November 3, 2023 Author Share Posted November 3, 2023 15 hours ago, szurszewski said: So you’re saying posting here magically solved your problem? That’s fantastic :) Yep! 2 Link to comment
Stiggy Posted November 3, 2023 Share Posted November 3, 2023 3 hours ago, BABABeemer said: I saw these manual chain tensioners for sale on a popular marketplace. I wonder if they would do the trick? $105 for a pair. I imagine only one would be required? As I understand it, manual tensioners like these do not perform the same as the adjustment tensioner for aligning cams. The manuals allow the motorcycle to be operated without hydraulic tensioners. The cam adjustment tensioner puts way more pressure on the chain solely so that the cams can be aligned properly. (You can't run the bike with an adjustment tensioner in place.) 1 Link to comment
Boxflyer Posted November 3, 2023 Share Posted November 3, 2023 I already bought this in an effort to make a Cam Chain Tensioner specifically needed if you are doing the Cam Alignment Adjustment. There was nothing I could use from these and I ended up wasting my money. It was the same thing with the eBay TDC pin and WetHead Alignment Jig…unacceptable poor quality machining and sloppy tolerances that could cause you to actually make the Cam Timing WORSE that when you started! 4 2 Link to comment
szurszewski Posted November 4, 2023 Share Posted November 4, 2023 3 hours ago, Boxflyer said: There was nothing I could use from these and I ended up wasting my money. Well, you learned something - so that should be worth something. At least that's what they kept telling me when I was writing those tuition checks in college... Link to comment
