BABABeemer Posted October 12, 2023 Share Posted October 12, 2023 I recently acquired a 2016 RTP at auction. It was advertised with no key so I ordered one from BMW. Meanwhile, I discovered a spare key in the storage compartment. I tried turning on the ignition and it is totally dead. If it is an unchipped key won’t a dash light come on? The bike has a new battery and the fuses show continuity with an ohm meter. When I installed the battery, there didn’t seem to be any parasitic draw when I connected the negative terminal. Now I’m at a loss. Any ideas? TIA. Link to comment
BABABeemer Posted October 13, 2023 Author Share Posted October 13, 2023 I guess the key has a dead chip. I was expecting to at least see a dash light to come on. BMW’s have a pretty bulletproof security system. Link to comment
Bernie Posted October 13, 2023 Share Posted October 13, 2023 Does this bike have 2 batteries? Link to comment
BABABeemer Posted October 13, 2023 Author Share Posted October 13, 2023 42 minutes ago, Bernie said: Does this bike have 2 batteries? Yes, both are installed and fully charged. Link to comment
Bernie Posted October 13, 2023 Share Posted October 13, 2023 I don’t know. Under the seat on a standard RT are 3 fuses. Two mounted on the seat bracket and a bib one next to the ECU, or whatever it is called. Are they there? Tested good. On the older RTs if the chip could not be read by the antenna, it would display EWA or something. But it would display something. I think in the conversion from RTP duty to civilian, someone either cut some wires or unplugged something. Link to comment
BABABeemer Posted October 14, 2023 Author Share Posted October 14, 2023 6 hours ago, Bernie said: I don’t know. Under the seat on a standard RT are 3 fuses. Two mounted on the seat bracket and a bib one next to the ECU, or whatever it is called. Are they there? Tested good. On the older RTs if the chip could not be read by the antenna, it would display EWA or something. But it would display something. I think in the conversion from RTP duty to civilian, someone either cut some wires or unplugged something. Members 138 Joined Aug 2003 Author Posted 2 minutes ago Problem solved! I went to Sierra BMW and talked to Chris. He was kind enough to show me one of their RTPs that was in for service. I immediately noticed that it had a cable hooked up to the ignition switch that was missing on mine! Chris took the time to unhook the cable so I could see what connector to look for. When I got home I remembered that when I received the bike, that cable had been disconnected and laying near where the radio rack was. I had taped it over and hidden it away. As soon as I hooked up that cable in the hidden receptacle, everything came on with the key! Thanks for all your input! 1 Link to comment
