Dave P Posted September 24, 2023 Share Posted September 24, 2023 2007 R1200RT I'm adding Hyper-Lites to my brake light. It's all hooked up except the connection to switched 12v power. On the MOA site I read there is a 2 conductor plug under the passenger seat, left rear, intended for a Powerlet socket. I heard there is switched 12v power on the red/green wire. Would this red/green wire be my source to tap into for this Hyper-Lite? Thanks, Dave Link to comment
lkraus Posted September 24, 2023 Share Posted September 24, 2023 The red/green will work. Expect the light to remain on for a time after the ignition is turned off. I have had the Skene P3 lights for many years, so had to look to see which wire I used. I thought I had used a wire for the optional alarm system (which I do not have) but I now think it is for the heated rear seat (also not present). Sometimes I look at something I did years ago and wonder how I made the decision. I suspect I just tested wires at unused connector until I found a switched wire. There may be a better choice, but I've been using a white/green wire in the tail section without a problem or a shutdown delay. Link to comment
Skywagon Posted September 24, 2023 Share Posted September 24, 2023 Ive used hyper-lites on my last 3 bikes. Mine came with detailed instruction on where to tap the wires. You might contact them and see if they have a recommendation for you. Link to comment
Dave P Posted September 24, 2023 Author Share Posted September 24, 2023 Sky- from what I remember, it wasn't specific to my bike, just said "switched 12v". Don't want to take all the bodywork off to hook to something up front (just put it all back on). As a test I just hooked a jumper to the positive on the battery. I think I'll try that RedGreen Show line see how it works. D Link to comment
pwillikers Posted September 27, 2023 Share Posted September 27, 2023 Here's what I did. Red/Green works. Link to comment
Dave P Posted September 28, 2023 Author Share Posted September 28, 2023 Yeah I went with the red/green and it worked great. D Link to comment
