PAGS Posted September 24, 2023 Share Posted September 24, 2023 Hi all, my first post and hope there might be someone that can help me with this... Bike : 2003 GS 54k miles Relevant info : 8 k miles ago ( 16 mo ) new HES , new hoses in tank and supply and return to tank.. new pump and filter .. ran fine except for the whine from the pump. Current situation : replaced the fuel pump only to stop the whine. ( same filter ) ............... for full disclosure also changed the air filter at that time....... since then bike starts fine but now it runs anywhere from 1 to 3 min..and stops cold.. Usually cuts out just over 2 min... If I let it sit for about 10 sec it starts and runs again until it stops.. I was able to get a video of it stopping and then trying to restart until it runs again. It seems to starve for fuel for several seconds and then starts and runs again for 2 min... I am just stumped.. What I tried : I removed mesh bag in case that was starving it, but no change... Checked all the hoses and clamps in tank and all seem correct... tight clamps and fresh, intact hoses.. I swapped back to the original pump to get back to a baseline of proper running. and still have the same condition.. thanks for any suggestions... https://share.icloud.com/photos/0e7792JT-w1lZ2Z29GfRiF3Tg Link to comment
Rinkydink Posted September 24, 2023 Share Posted September 24, 2023 When it quits, open gas cap. Did you hear a whoosh? Try starting immediately. The vent tube may be plugged. Just a shot in the dark. Link to comment
PAGS Posted September 24, 2023 Author Share Posted September 24, 2023 ah yes, I forgot to mention, I ran the bike with the cap open and no change. Pulling vacuum in tank could lead to this kind of thing.. thanks !!! shots in the dark are fine.. thats where I am at.. 1 Link to comment
dirtrider Posted September 24, 2023 Share Posted September 24, 2023 15 hours ago, PAGS said: Hi all, my first post and hope there might be someone that can help me with this... Bike : 2003 GS 54k miles Relevant info : 8 k miles ago ( 16 mo ) new HES , new hoses in tank and supply and return to tank.. new pump and filter .. ran fine except for the whine from the pump. Current situation : replaced the fuel pump only to stop the whine. ( same filter ) ............... for full disclosure also changed the air filter at that time....... since then bike starts fine but now it runs anywhere from 1 to 3 min..and stops cold.. Usually cuts out just over 2 min... If I let it sit for about 10 sec it starts and runs again until it stops.. I was able to get a video of it stopping and then trying to restart until it runs again. It seems to starve for fuel for several seconds and then starts and runs again for 2 min... I am just stumped.. What I tried : I removed mesh bag in case that was starving it, but no change... Checked all the hoses and clamps in tank and all seem correct... tight clamps and fresh, intact hoses.. I swapped back to the original pump to get back to a baseline of proper running. and still have the same condition.. thanks for any suggestions... https://share.icloud.com/photos/0e7792JT-w1lZ2Z29GfRiF3Tg Morning PAGS Try unplugging the o2 sensor, just over 2 minutes running is usually when the o2 sensor comes on-line. After a stall then restart it typically takes a shorter time for the o2 sensor to come back on-line again. A failed or failing o2 sensor can easily cause an engine stall when the Motronic is fueling to it. . 1 Link to comment
PAGS Posted September 24, 2023 Author Share Posted September 24, 2023 BIG THANKS Oracle..! after unplugging the connector it ran for over 7 minutes... previously it never made it to 3 min....... PLugged it and stopped at 1: 25 min... unplugged and I stopped engine at over 5 min run time... this is the issue.. BIG thanks again for this... I feel great>> :) 2 Link to comment
dirtrider Posted September 24, 2023 Share Posted September 24, 2023 13 hours ago, PAGS said: BIG THANKS Oracle..! after unplugging the connector it ran for over 7 minutes... previously it never made it to 3 min....... PLugged it and stopped at 1: 25 min... unplugged and I stopped engine at over 5 min run time... this is the issue.. BIG thanks again for this... I feel great>> :) Evening PAGS That is good news. When you remove the o2 sensor see if the o2 wire pigtail was hanging down on the catalytic converter. If it was/is then be sure re-route & secure the replacement so that can't happen again. An OEM sensor is quite expensive but a universal sensor will work just fine. Just be sure splice the wires correctly as most universal sensors use different wire colors for the heater & sensor side circuits so don't just match wire colors. Also, if using a universal sensor DO NOT solder the wire connections as the o2 sensor gets it's reference air down through the wire strands & soldering the connections blocks that needed external reference air. Added: If your o2 sensor pigtail is running along or near the R/H spark plug wire then reroute it to be away from the spark plug wire then plug it in & retry running the engine. If the plug wire is too close to the o2 sensor pigtail that can drive the engine fueling crazy. Link to comment
PAGS Posted September 25, 2023 Author Share Posted September 25, 2023 Many thanks for the added advice Oracle. I saw there are some used sensors with the proper connecter on Ebay.. seems low risk... Do you recommend a new universal sensor instead of used OEM ?? thanks ! Link to comment
Camhead64 Posted September 25, 2023 Share Posted September 25, 2023 You may want to try these guys instead of Ebay. https://www.euromotoelectrics.com/searchresults.asp?Search=oxygen+sensor&Submit= 1 1 Link to comment
dirtrider Posted September 25, 2023 Share Posted September 25, 2023 8 hours ago, PAGS said: Many thanks for the added advice Oracle. I saw there are some used sensors with the proper connecter on Ebay.. seems low risk... Do you recommend a new universal sensor instead of used OEM ?? thanks ! Morning PAGS Nothing wrong with an E-Bay sensor if you get a decent one. Problem is, a lot of the stuff on E-Bay comes from crashed or parted motorcycles so you could easily get a lazy or failed o2 sensor. There is no real reliable way to test used o2 sensors so who knows what you will get. A good E-Bay seller will probably refund you if you get a bad one but it is still a lot of work to install just to have to do it again. Also, nothing wrong with a name brand universal sensor as long as it is installed correctly with proper wire splices. Euromotoelectrics is not a bad place to buy an o2 sensor if you just want a plug & play, just make sure that if you buy from them that you get the correct connector as your 2003 could have either the older larger round connector or new smaller eared type connector. So make sure that you buy an o2 sensor with the correct connector for your 1150 GS. Link to comment
PAGS Posted September 26, 2023 Author Share Posted September 26, 2023 Thanks Oracle All true what you said about used items, and thats why I kept looking ,, Found a universal sensor for $79 at Beemer Boneyard and then at EME has an OEM for $ 99 marked down to 89 so thats what I will do.. O2 sensor, cable and connector Yes important about the connector and yes crimping wires is good if the crimp is solid , but also thats just another possible place for a failure.. I feel most comfortable with what EME has so thats my direction. I used to work in the connector industry and those items are highly engineered and need to be terminated correctly or it will fail over time.. Again many thanks! Link to comment
Skywagon Posted September 26, 2023 Share Posted September 26, 2023 DR… if soldering is a no no, is the correct way to crimp using the metal part of a connector like you have shown us before? Link to comment
dirtrider Posted September 26, 2023 Share Posted September 26, 2023 On 9/25/2023 at 9:36 PM, Skywagon said: DR… if soldering is a no no, is the correct way to crimp using the metal part of a connector like you have shown us before? Morning David Personally I use dedicated splice clips. Those are designed for the proper connection of 2 wires. But to achieve a solid lasting connection you need to use the PROPER crimping tool at the correct crimping pressure. The proper crimping tool doesn't just squeeze the clip tight but actually folds the clip ears in to make a very solid connection. (personably I haven't ever had a failure using a good quality splice clip & the proper crimping tool) Another possibility is to use special butt connectors designed for ABS speed sensor wire damage repair, those are heat shrink/glue covered so seal moisture out, see way below__ Splice clip use showing proper crimp, see below___ You can make your own splice clip from the center of a terminal as long the crimping tails are correct for double wire size that is being spliced. Splice clip made from center of terminal, see below__ 1 Link to comment
PAGS Posted September 26, 2023 Author Share Posted September 26, 2023 Oracle, the home made butt splice from modifying a terminal is very clever... !! got that one tucked away in my mind in case its needed nice documentation too... Link to comment
PAGS Posted September 29, 2023 Author Share Posted September 29, 2023 Update on the stalling... installed the new O2 from EME ... Now it stops at approx 20-30 sec I scanned with GS 911 and the O2 sensor is running above 1100 mv... The one I replaced gave a similar result... unplugged the O2 and I ran it to 3 min and I stopped it . So I think it would keep going.. Also now the bike fires up immediately after stopping , with old sensor it would not fire for at least 5-10 sec I am completely baffled by this.. Open to any ideas....... thanks Link to comment
