Hadabadachada Posted September 17 Share Posted September 17 2013R1200R K27 Was pushing the bike into the yard last night and heard this kinda “moaning” kinda sound when moving the bike forward and backward. sounds like maybe a seal needs lube or something needs lube. Anyone ever heard this? is this a normal sound? FullSizeRender.MOV Link to comment
TEWKS Posted September 18 Share Posted September 18 7 hours ago, 9Mary7 said: Brake pads?? Yeah, maybe a frozen caliper? @Boxflyer showed me how those pins need lube to keep the calipers/pads from hanging on the rotors. Link to comment
TEWKS Posted September 19 Share Posted September 19 Easy to check, unbolt and lift off the caliper and see if the noise is gone. Link to comment
Skywagon Posted September 19 Share Posted September 19 sounded like dragging brakes to me too...but hard to tell over the intraweb. Tewks is right...unbolt calipers and check again. Link to comment
Hadabadachada Posted September 20 Author Share Posted September 20 Heyyyy, a “totally normal” I like that, thank you! i figured the brake scrape would grab the attention, but below that is the kinda whine/moan. seems like maybe the seal getting rubbed on. No leaks or anything so I’m not worried at this point. Link to comment
Skywagon Posted September 20 Share Posted September 20 I would say it's not unusual, but if your brakes are dragging, they are wearing and getting warm. I wouldn't say normal. I would still pull the pads which should take 5 minutes - check again. If the sound is gone, then thoroughly clean and lightly lube the pins they slide on. Don't depress the brakes with the pads out or you will likely cause the pistons to come out and that won't be much fun. Link to comment
