Paskale Posted September 17, 2023 Share Posted September 17, 2023 Good morning! My right signal lights stay on and are not flashing. Left lights work just fine. we can here the relay working left side but nothing on the right side. anybody have an idea of what it could be? Link to comment
dirtrider Posted September 17, 2023 Share Posted September 17, 2023 22 minutes ago, Paskale said: Good morning! My right signal lights stay on and are not flashing. Left lights work just fine. we can here the relay working left side but nothing on the right side. anybody have an idea of what it could be? Morning Paskale Yes, a number of ideas but without having the motorcycle in front of me then mainly guesses. First, would be there is some resistance in the R/H side bulbs, or grounds, or wiring that allows the bulbs to light but not put enough load on the flasher relay to make it flash. Or, possibly a failed flasher relay. Do both the R/H side bulbs look as bright as the L/H side bulbs? Are the R/H side bulbs the correct ones? You want to check everything else out before going after the turn signal relay as a new turn signal relay from BMW is $352.00. Probably an E-Bay "used" is a more cost effective alternative. Link to comment
Paskale Posted September 17, 2023 Author Share Posted September 17, 2023 i had a idle problem and brought it to the garage they changed the battery and my acceleration cable was going trough in a bad spot so they re runned it. then i realised on the way home that the flasher wasnt flashing on the right side. thay are as bright as the left side Link to comment
Paskale Posted September 17, 2023 Author Share Posted September 17, 2023 a friend of mine think its the thermal switch Link to comment
Michaelr11 Posted September 17, 2023 Share Posted September 17, 2023 2 hours ago, Paskale said: a friend of mine think its the thermal switch The flasher relay is electronic. Thermal switch flasher relays are a few decades earlier than this. Anyone you know with a bike with the same flasher relay? Simple swap would prove if the problem is the relay. Link to comment
dirtrider Posted September 17, 2023 Share Posted September 17, 2023 5 hours ago, Paskale said: i had a idle problem and brought it to the garage they changed the battery and my acceleration cable was going trough in a bad spot so they re runned it. then i realised on the way home that the flasher wasnt flashing on the right side. thay are as bright as the left side Afternoon Paskale If it worked when to took it into the shop & didn't work after you picked it up then take it back to the shop that did the work. Ther is no thermal flasher unit in your BMW the flasher relay is electronic, very complex & very expensive (about $352.00 =Tax new from BMW) Link to comment
