Beemer Maverick Posted September 16, 2023 Share Posted September 16, 2023 Hi all! I was trying to fix my bike after it shut down in the rain on me and I keep hitting dead ends on her. After letting the bike dry overnight it started up fine, but then I let it sit for a week and now? Nothing. As for what I have done so far I've replaced the following: - Full replacement of the fuel pump and filter in the tank (which was, admittedly, not the issue at all but was a good start) - New spark plugs - And just today new ignition coils. I am at my wits end on this thing and can't afford to keep shoving expensive parts at it. Link to comment
dirtrider Posted September 16, 2023 Share Posted September 16, 2023 13 minutes ago, Beemer Maverick said: Hi all! I was trying to fix my bike after it shut down in the rain on me and I keep hitting dead ends on her. After letting the bike dry overnight it started up fine, but then I let it sit for a week and now? Nothing. As for what I have done so far I've replaced the following: - Full replacement of the fuel pump and filter in the tank (which was, admittedly, not the issue at all but was a good start) - New spark plugs - And just today new ignition coils. I am at my wits end on this thing and can't afford to keep shoving expensive parts at it. Morning Beemer Maverick When an 1100 quits in the rain or when wet that is sign that the HES is probably deteriorated. The wiring pig tail on the HES (Hall Effect Sensor) tends to have the wire insulation crumble then the HES signal cross talks between the wires then you get no spark. Link to comment
Beemer Maverick Posted September 16, 2023 Author Share Posted September 16, 2023 1 minute ago, dirtrider said: Morning Beemer Maverick When an 1100 quits in the rain or when wet that is sign that the HES is probably deteriorated. HES? I'll see if I can't figure it out with the manual, but thank you! Link to comment
dirtrider Posted September 16, 2023 Share Posted September 16, 2023 3 hours ago, Beemer Maverick said: HES? I'll see if I can't figure it out with the manual, but thank you! Morning Beemer Maverick Just put HES into the search box at the top of this page then search HES, you can read for an hour+. Then any questions that you have come back & post them here. When you check your HES wire pig tail you will probably find it degraded so instead of buying a new (expensive) HES you might E-Mail GSAddict at arbcon@sunshinecoast.ca He re-wires them with correct high temperature wire & does a very professional job at making them as good or better than new. If you go with GSAdict he is in Canada so you need to follow his exact directions for sending it to him so you don't have to pay the duty or import fees. Link to comment
Beemer Maverick Posted September 16, 2023 Author Share Posted September 16, 2023 19 minutes ago, dirtrider said: Morning Beemer Maverick Just put HES into the search box at the top of this page then search HES, you can read for an hour+. Then any questions that you have come back & post them here. When you check your HES wire pig tail you will probably find it degraded so instead of buying a new (expensive) HES you might E-Mail GSAddict at arbcon@sunshinecoast.ca He re-wires them with correct high temperature wire & does a very professional job at making them as good or better then new. If you go with GSAdict he is in Canada so you need to follow his exact directions for sending it to him so you don't have to pay the duty or import fees. Thank you so much!! I really appreciate your help, I'll get it sent off and hopefully get this pretty bike back on the road in no time! Link to comment
Skywagon Posted September 16, 2023 Share Posted September 16, 2023 Beemer-Maverick....as DR said there is lots of info here on the HES. Follow the instructions for removal, marking the timing marks, for an easy re-installation. Link to comment
Paddler Posted September 16, 2023 Share Posted September 16, 2023 I watched a video that said the HES typically fail at ~70K miles. Is that true? Does the age of the bike matter? Also, in the video, he made a device to verify the sensor was at TDC as he was installing a new one. I'm assuming that by marking the original before removal eliminates the need to double check it? Link to comment
Beemer Maverick Posted September 16, 2023 Author Share Posted September 16, 2023 23 minutes ago, Paddler said: I watched a video that said the HES typically fail at ~70K miles. Is that true? Does the age of the bike matter? Also, in the video, he made a device to verify the sensor was at TDC as he was installing a new one. I'm assuming that by marking the original before removal eliminates the need to double check it? Mine failed at 90k, but all oilheads until about late 2002 are susceptible to this failure. Like everyone else said: it's a matter of when, not if. Though I got the sonofabitch out after some struggles with the Florida heat! Link to comment
Jim Moore Posted September 18, 2023 Share Posted September 18, 2023 Where in FL? if you're near Jacksonville I'll try to swing by and supervise when your new HES arrives. Link to comment
Beemer Maverick Posted September 18, 2023 Author Share Posted September 18, 2023 7 minutes ago, Jim Moore said: Where in FL? if you're near Jacksonville I'll try to swing by and supervise when your new HES arrives. Melbourne area, so not too close XD Link to comment
Jim Moore Posted September 19, 2023 Share Posted September 19, 2023 15 hours ago, Beemer Maverick said: Melbourne area, so not too close XD Roger that. Link to comment
Beemer Maverick Posted October 7, 2023 Author Share Posted October 7, 2023 So, a little update to this post, but I've gotten everything put back together and now it's just not turning over. I've done the timing, but can't seem to get her to start. Friend says it might be "bad gas" that's refusing to let the engine turn, but I have my doubts. It definitely wants to turn over, but it just won't/can't. Any ideas? Link to comment
Hosstage Posted October 7, 2023 Share Posted October 7, 2023 Is that battery fully charged? Bad gas has nothing to do with an engine turning over. Trying to fire, maybe, but not turning over. Link to comment
Beemer Maverick Posted October 7, 2023 Author Share Posted October 7, 2023 10 minutes ago, Hosstage said: Is that battery fully charged? Bad gas has nothing to do with an engine turning over. Trying to fire, maybe, but not turning over. it's on the charger now, which is what i figured might be the problem along with possibly not liking to start on the center stand. will update when i have a definite answer Link to comment
dirtrider Posted October 7, 2023 Share Posted October 7, 2023 15 minutes ago, Beemer Maverick said: it's on the charger now, which is what i figured might be the problem along with possibly not liking to start on the center stand. will update when i have a definite answer Afternoon Beemer Maverick If you locked the flywheel with a pin did you remove the locking pin? Is the side stand UP? Is it in neutral or clutch lever pulled in? Can you turn the engine over by hand? Link to comment
Beemer Maverick Posted October 7, 2023 Author Share Posted October 7, 2023 9 minutes ago, dirtrider said: Afternoon Beemer Maverick If you locked the flywheel with a pin did you remove the locking pin? Is the side stand UP? Is it in neutral or clutch lever pulled in? Can you turn the engine over by hand? Afternoon dirtrider! The pin is out, the side stand is up and it's in neutral, and i can turn it by hand. Link to comment
dirtrider Posted October 7, 2023 Share Posted October 7, 2023 1 minute ago, Beemer Maverick said: Afternoon dirtrider! The pin is out, the side stand is up and it's in neutral, and i can turn it by hand. Afternoon Beemer Maverick OK, get the battery fully charged then see what you have. Link to comment
Beemer Maverick Posted October 8, 2023 Author Share Posted October 8, 2023 19 hours ago, dirtrider said: Afternoon Beemer Maverick OK, get the battery fully charged then see what you have. Good morning dirtrider, Let the battery fully charge only to realize there wasn't really any gas in it, which fouled the plugs. Not the update I was hoping for, since it still won't catch despite my pleading with it. Letting the battery charge up again and hopefully I'll be back with an update today. Link to comment
