joeb Posted September 14 Share Posted September 14 Hi. 09 r1200 gs. A few months ago I stalled the bike and it was totally dead electrically. Tightened the battery cables and after about 1/2 hr got it restarted. Got home, cleaned connectors and retightened . Bike ran well for a while. Came out to start bike one day and it was dead. Battery was 5 yrs old so replaced it with new YUSA AGM battery. Ran fine. Been off bike for about 10 days and now it was dead. Battery showed 10 volts. Charged it up and starts fine. With engine running steady 14.6 volts to battery. Previously I've left it unattended for weeks and it would start. I haven't added any equipment so have no idea what has changed. Any ideas from you ? Thank you. Link to comment
dirtrider Posted September 14 Share Posted September 14 12 minutes ago, joeb said: Hi. 09 r1200 gs. A few months ago I stalled the bike and it was totally dead electrically. Tightened the battery cables and after about 1/2 hr got it restarted. Got home, cleaned connectors and retightened . Bike ran well for a while. Came out to start bike one day and it was dead. Battery was 5 yrs old so replaced it with new YUSA AGM battery. Ran fine. Been off bike for about 10 days and now it was dead. Battery showed 10 volts. Charged it up and starts fine. With engine running steady 14.6 volts to battery. Previously I've left it unattended for weeks and it would start. I haven't added any equipment so have no idea what has changed. Any ideas from you ? Thank you. Evening joeb It sounds like something is staying alive after shutdown. Do you have anything hooked to the factory powers sockets or to the front GPS 12V connector? Any added lights etc? Any type of added fuse box under the seat? Do you have small DVM & know how to measure for a parasitic drain? Link to comment
joeb Posted September 14 Author Share Posted September 14 Thanks for the response. I think I had a cell phone charger plugged into the GPS socket. As far as I can tell , that socket doesn't stay hot when bike is shut down. Nothing new has been added recently. I assume that even while shut down some current will be draining due to the electronics ? Not sure how to measure amount of current. If no current is supposed to flow, I could put a tester between the battery and it's cable. Link to comment
joeb Posted September 15 Author Share Posted September 15 My plan as of now is to get battery up to full charge , then see how much voltage drop occurs over nite or over a few days . If it drops significantly I will charge it up again, disconnect it from bike then monitor its voltage to see if the new battery is faulty. One additional point. I do have halogen lights on the bike. I don't generally turn them off while it sits as they will not turn on without the engine running . I do see a module in the line leading to the lights. Is it possible that the module draws power when the switch is on even though the lights themselves are not drawing current ? If so, would turning off the switch stop that module from drawing current ? The module is connected to the battery. As I pointed out before, new problem that has developed without any new wiring added. Any thoughts on my process of elimination would be appreciated. Thanks Link to comment
dirtrider Posted September 15 Share Posted September 15 8 hours ago, joeb said: My plan as of now is to get battery up to full charge , then see how much voltage drop occurs over nite or over a few days . If it drops significantly I will charge it up again, disconnect it from bike then monitor its voltage to see if the new battery is faulty. One additional point. I do have halogen lights on the bike. I don't generally turn them off while it sits as they will not turn on without the engine running . I do see a module in the line leading to the lights. Is it possible that the module draws power when the switch is on even though the lights themselves are not drawing current ? If so, would turning off the switch stop that module from drawing current ? The module is connected to the battery. As I pointed out before, new problem that has developed without any new wiring added. Any thoughts on my process of elimination would be appreciated. Thanks Morning joeb On the cell phone charger--- I have seen GPS units with built in power converters keep part of the system alive so don't totally discount your cell phone charger as causing the issue. On the halogen lights relay, I can't see enough of the circuit to tell what or how it is wired but something to look into. If you bought that motorcycle used are you sure then the socket that your cell phone charger is plugged into hasn't been directly wired to the battery (a number of 1200 riders do that). Link to comment
joeb Posted September 15 Author Share Posted September 15 Still checking things out. Charge on battery last night 12.82v. Disconnected the negative cable and halogen wire from battery, checked voltage just now . Battery showing 12.64v. So a small drop. Reconnected the negative cable and light wires . Will check for voltage drop in a while . When I disconnected negative bat cable and put my tester between the cable and battery negative terminal it did show voltage which I would think is normal as the electronics must use some electricity ? Clock function comes to mind. I don't know how to tell how much electricity is being used to determine if flow is normal or excessive. Link to comment
TSConver Posted September 15 Share Posted September 15 15 minutes ago, joeb said: Still checking things out. Charge on battery last night 12.82v. Disconnected the negative cable and halogen wire from battery, checked voltage just now . Battery showing 12.64v. So a small drop. Reconnected the negative cable and light wires . Will check for voltage drop in a while . When I disconnected negative bat cable and put my tester between the cable and battery negative terminal it did show voltage which I would think is normal as the electronics must use some electricity ? Clock function comes to mind. I don't know how to tell how much electricity is being used to determine if flow is normal or excessive. Put an amp meter between the negative post and the negative cable. Probably should see about 50 mA parasitic draw. Anything over that is a problem. Have to wait for everything to go to sleep that can take 5 to 10 min then the amp draw should drop down to the 50 mA range. Link to comment
dirtrider Posted September 15 Share Posted September 15 51 minutes ago, joeb said: Still checking things out. Charge on battery last night 12.82v. Disconnected the negative cable and halogen wire from battery, checked voltage just now . Battery showing 12.64v. So a small drop. Reconnected the negative cable and light wires . Will check for voltage drop in a while . When I disconnected negative bat cable and put my tester between the cable and battery negative terminal it did show voltage which I would think is normal as the electronics must use some electricity ? Clock function comes to mind. I don't know how to tell how much electricity is being used to determine if flow is normal or excessive. Morning Joeb When I disconnected negative bat cable and put my tester between the cable and battery negative terminal it did show voltage which I would think is normal--- That is usually not a valid test as every time you disconnect the cable then reconnect (or place your meter between the cable & battery post) the system comes partially alive. So disconnect the cable from the battery post, then put a jumper between the cable & battrey post, NOW connect your meter to the battery post & the cable. Then with the jumper still in place give it about 20 minutes for all to go back sleep. THEN remove the jumper & read the actual parasitic draw. My BMW data shows about a 2.5 Ma to 3 Ma draw is normal (after system shutdown) on the 2009 1200GS. You can't measure using voltage as that won't tell you anything useful. Link to comment
joeb Posted September 15 Author Share Posted September 15 My findings after following the procedure as you described. Using a cheap analog meter DC parasite draw shows about 1Ma. Battery has been holding a steady 12.64 v. It appears battery and electrical systems are normal. The GPS socket does not stay hot after bike shut down, so I still have no idea why the battery was dead after 9 days sitting in a warm garage. Thanks for your help. Link to comment
dirtrider Posted September 15 Share Posted September 15 2 hours ago, joeb said: My findings after following the procedure as you described. Using a cheap analog meter DC parasite draw shows about 1Ma. Battery has been holding a steady 12.64 v. It appears battery and electrical systems are normal. The GPS socket does not stay hot after bike shut down, so I still have no idea why the battery was dead after 9 days sitting in a warm garage. Thanks for your help. Evening joeb That accessory socket shut down this time but does it always shut down? On the GPS systems that I have seen keep the GPS circuit alive it wasn't 100% of the time, it was kind of random. Link to comment
joeb Posted September 15 Author Share Posted September 15 Good to know. Resolved to unplug charger and hope that is the cure. I do carry a jump start pack with me just in case. Thanks gor all your help. Cheers Link to comment
