Bigboyzbeemertoyz Posted September 4, 2023 Share Posted September 4, 2023 So 5 years ago with a massive fuel leak, I had a new fuel pump installed, courtesy of BMW. Now that pump is leaking at the base of the high pressure output of the pump. I know you can buy aftermarket metal fittings from Beamer boneyard but I’m not sure how to remove that old fitting. There’s a plastic nut that a 19mm wrench fits, but it just spins and doesn’t seem to be loosening. I haven’t pulled the pump out but was hoping not to. Any help would be greatly appreciated! Link to comment
dirtrider Posted September 4, 2023 Share Posted September 4, 2023 Afternoon Bigboyzbeemertoyz Put an arrow on your picture to show us EXACTLY where it is leaking from. Link to comment
Bigboyzbeemertoyz Posted September 5, 2023 Author Share Posted September 5, 2023 Edited with better photo! Link to comment
Bigboyzbeemertoyz Posted September 5, 2023 Author Share Posted September 5, 2023 Discovered there's alot of information at https://www.advrider.com/f/threads/quick-disconnect-replacement-pictorial-and-boss-clamps.852502/ I think I fixed the problem!! Link to comment
