joeb Posted September 2, 2023 Share Posted September 2, 2023 Morn all. Just a general curiosity question today. I switch between street/dirt tires and road tires on my GS. In general, if riding only on the street, will which type of tire will give higher milage ? Reason for alternating tires is to save my " good " road tires for long rides in the twisties. The 85/15 tires seem perfectly adequate for my shorter local rides . Since I've previously run road tires exclusively I have NO idea of expected milage with combo tires. Just asking. Thanks Link to comment
dirtrider Posted September 2, 2023 Share Posted September 2, 2023 30 minutes ago, joeb said: Morn all. Just a general curiosity question today. I switch between street/dirt tires and road tires on my GS. In general, if riding only on the street, will which type of tire will give higher milage ? Reason for alternating tires is to save my " good " road tires for long rides in the twisties. The 85/15 tires seem perfectly adequate for my shorter local rides . Since I've previously run road tires exclusively I have NO idea of expected milage with combo tires. Just asking. Thanks Morning joeb Difficult to give you a full answer but typically road-only tires have longer life ALL things being equal. Road-only tires usually have more rubber & smaller sipes so there is just more rubber available contacting the road surface. BUT, there are other factors involved, With (good traction) road-only tires personally I tend to ride them a lot harder & definitely brake a lot harder form speed so that increases the potential for road-only tire wear. It can also depend on the tire rubber hardness as some combination on-road/off-road tires have harder rubber & wear better than softer (mainly off-road type tires). But in my experience the harder rubber combination on-road/off-road tires are borderline dangerous on the street for anything but clean dry roads. Link to comment
joeb Posted September 2, 2023 Author Share Posted September 2, 2023 Thanks for your input. I agree that the variables in riding style and road conditions make the results of direct comparisons highly suspect. I was curious as to whether the harder rubber of combo tires would outweigh the disadvantage of tread design to give higher milage. As a side note. My Metzler Tourance tires seem to give excellent grip on dry roads . I do push them harder than a lot of riders with no issue, but as you say , only on dry clean roads but not as aggressively as I would with my road tires. Link to comment
