Dave P Posted August 14, 2023 Share Posted August 14, 2023 2007 1200RT- I swung the final drive down to drain the oil in my final, need to grease the male / female splines. I want to be sure to use the correct grease. Can I get Assembly Lube (Autozone has Lucas) to use in there? I just have simple synthetic grease (for brake work) and a tube of BMW lubricant #10 (lithium extreme pressure grease). BelRay is way across town. Thanks, Dave Link to comment
9Mary7 Posted August 15, 2023 Share Posted August 15, 2023 1 hour ago, Dave P said: 2007 1200RT- I swung the final drive down to drain the oil in my final, need to grease the male / female splines. I want to be sure to use the correct grease. Can I get Assembly Lube (Autozone has Lucas) to use in there? I just have simple synthetic grease (for brake work) and a tube of BMW lubricant #10 (lithium extreme pressure grease). BelRay is way across town. Thanks, Dave As long as it's got Molybdenum in it......most engine assembly lube does. Link to comment
dirtrider Posted August 15, 2023 Share Posted August 15, 2023 11 hours ago, Dave P said: 2007 1200RT- I swung the final drive down to drain the oil in my final, need to grease the male / female splines. I want to be sure to use the correct grease. Can I get Assembly Lube (Autozone has Lucas) to use in there? I just have simple synthetic grease (for brake work) and a tube of BMW lubricant #10 (lithium extreme pressure grease). BelRay is way across town. Thanks, Dave Morning Dave That is a highly debated area, riders use a lot of different greases. The problem is we don't see any follow up on how long it lasted or how long it worked properly. It also depends on the operating conditions that the motorcycle was/is ridden in. If you live in a dry area & don't ride in the rain then you probably won't notice a lot of difference between the available moly based greases, if you ride in the wet, or power wash your motorcycle, then then grease choice can make a big difference. Personally I still use the BMW recommended Optimoly TA on the splines & the Staburags NBU 30 PTM to properly seal the rubber boot. Luckily I still have some Optimoly TA as it doesn't seem to be available any longer. Some riders are using Honda Moly 60 on the splines (if you can still find the Moly 60 as Honda has replaced it with the Honda M-77). You definitely want to properly seal the rubber boot as moisture can get in but not always get out. Personally I am kind of anal about what grease I use & how I seal the boot (I ride in a lot of wet at speed & do a number of water crossings). What I use just plain works but possibly other products will as well but I stay with what I know works. You might wait a little while to see what others are using for spline lube & boot sealing. Link to comment
Dave P Posted August 15, 2023 Author Share Posted August 15, 2023 Not in a hurry, I've got other things disassembled on the bike anyway. It's just sitting there with its final hanging down. Oil in the roast pan. Im not in the desert, but generally don't ride too much in the rain. I never power wash the bike. I did notice lots of grey grease around the boot flange. That's the seal for the boot I guess. Boot itself looks to be in good shape- no rips. Sounds like different grease for splines vs boot, right? D Link to comment
KDeline Posted October 6, 2023 Share Posted October 6, 2023 On 8/15/2023 at 6:04 AM, dirtrider said: Personally I still use the BMW recommended Optimoly TA on the splines & the Staburags NBU 30 PTM to properly seal the rubber boot. Luckily I still have some Optimoly TA as it doesn't seem to be available any longer. I have about one squeeze left of old Staburags from the early 80's that I have used over the years for far and few spline lubes. Used most of it on the old airheads. Can the NBU 30 PTM also be used on splines? Looking to pull shaft of 98 RTP, 123.000 miles, inspect and lube. It has never been pulled, getting a little worried about it. Link to comment
bruce2000ltc Posted October 7, 2023 Share Posted October 7, 2023 I've been using Loctite Moly Paste 51048 for years and it come highly recommended. It's not cheap but it will last for years. Amazon.com: Loctite 234227 LOC51048 Moly Paste Anti-Seize Compound : Automotive Amazon.com: Loctite 234227 LOC51048 Moly Paste Anti-Seize Compound : Automotive www.amazon.com 1 Link to comment
dmsantam Posted January 29 Share Posted January 29 I use Honda 77 for the splines and CRC sta-lube for the boots. I use it for brake jobs and it has worked well in this application for me too. https://www.crcindustries.com/synthetic-brake-caliper-grease-12-wt-oz/ Link to comment
