Hadabadachada Posted August 6, 2023 Share Posted August 6, 2023 2013 R1200R So I’m looking to replace my fuel filter. I have KL145 from my R1100 laying around and wondering if anyone’s using those in the camhead? looks like it’s a new part number so different filter. Just wondering if anyone’s used anything other than the OEM ? Link to comment
dirtrider Posted August 6, 2023 Share Posted August 6, 2023 7 hours ago, Hadabadachada said: 2013 R1200R So I’m looking to replace my fuel filter. I have KL145 from my R1100 laying around and wondering if anyone’s using those in the camhead? looks like it’s a new part number so different filter. Just wondering if anyone’s used anything other than the OEM ? Afternoon Hadabadachada It might work, I haven't ever tried it myself. It will probably fit but could rattle around unless you can wrap it with some high temperature resistant foam. Link to comment
Hadabadachada Posted August 6, 2023 Author Share Posted August 6, 2023 Maybe I can used something to wrap it. I may actually have a foam sleeve from a quantum fuel pump. 👍🏼 I just don’t know how fuel filters work, as in if they have different rates of flow, or if different sizes have different effects on things. like what if I got some of them small in line filters people use on their airheads and just threw that in instead? Link to comment
dirtrider Posted August 6, 2023 Share Posted August 6, 2023 Just now, Hadabadachada said: Maybe I can used something to wrap it. I may actually have a foam sleeve from a quantum fuel pump. 👍🏼 I just don’t know how fuel filters work, as in if they have different rates of flow, or if different sizes have different effects on things. like what if I got some of them small in line filters people use on their airheads and just threw that in instead? Afternoon Hadabadachada You definitely don't want to use a gravity flow fuel filter. You need a high pressure fuel injection type filter. Remember your fuel injected engine fuel-pump pumps a lot more fuel through the filter at a LOT higher pressure. As for actual filter element size, you would have to cut both filters apart to see how much filtration is used in each one. Personally I would (and do) just use the correct fuel filter as I know it works as intended. Link to comment
