PastorJay Posted August 3, 2023 Share Posted August 3, 2023 What is the recommended grease to use on the front axle of the r1200rt. Thank you. Link to comment
MikeB60 Posted August 3, 2023 Share Posted August 3, 2023 I use high temperature wheel bearing grease. 1 Link to comment
dirtrider Posted August 3, 2023 Share Posted August 3, 2023 9 hours ago, PastorJay said: What is the recommended grease to use on the front axle of the r1200rt. Thank you. Evening Pastor Jay I agree with Mike, a good quality high temperature Lithium based wheel bearing grease will work about as good as anything. Just use a decent quality grease with a good ( 500°f or so) dropping temperature as the front hub can run fairly warm during heavy braking events. The grease's main function is to prevent corrosion on the axle due to water/moisture entry, with a secondary function to lubricate the seal that rides on the axle. 1 Link to comment
PastorJay Posted August 4, 2023 Author Share Posted August 4, 2023 14 hours ago, dirtrider said: Evening Pastor Jay I agree with Mike, a good quality high temperature Lithium based wheel bearing grease will work about as good as anything. Just use a decent quality grease with a good ( 500°f or so) dropping temperature as the front hub can run fairly warm during heavy braking events. The grease's main function is to prevent corrosion on the axle due to water/moisture entry, with a secondary function to lubricate the seal that rides on the axle. Thanks for the help. Link to comment
