Agboett Posted July 22, 2023 Share Posted July 22, 2023 I had the rear brake & caliper serviced less than 200 miles ago -- I got home from a 30 mile ride & found this -- Should I be upset at the shop or is this bad luck ? Opinions wanted 2003 bmw r1150r Link to comment
Rinkydink Posted July 22, 2023 Share Posted July 22, 2023 I don’t think luck was involved here. Shop is to blame if they’re the last to touch it. That could’ve ended up being catastrophic. Link to comment
Agboett Posted July 22, 2023 Author Share Posted July 22, 2023 Gow could those bolts come free ? Link to comment
AviP Posted July 22, 2023 Share Posted July 22, 2023 That's not bad luck but definitely a bad/careless mechanic. Any person on this forum who has worked on brakes will attest to that. The shop needs to fix that on their dime. Period! Link to comment
Skywagon Posted July 22, 2023 Share Posted July 22, 2023 That^^^^^^. I’d be explaining to the shop and the owner you could have killed me. Fix it right this time on your dime. Link to comment
Rinkydink Posted July 23, 2023 Share Posted July 23, 2023 4 hours ago, Agboett said: Gow could those bolts come free ? I vote for not torqued correctly. 2 Link to comment
MikeB60 Posted July 23, 2023 Share Posted July 23, 2023 That sucks. They didn't clean the pins either. Link to comment
wbw6cos Posted July 23, 2023 Share Posted July 23, 2023 Glad you made it unscathed. Did the rim get damaged? Also, if you take it back to the shop, you will have to figure out a way to secure the caliper (doubtful that you have spare bolts) or have it towed. Good luck. Link to comment
Joe Frickin' Friday Posted July 24, 2023 Share Posted July 24, 2023 16 hours ago, wbw6cos said: have it towed. that should be the shop’s responsibility (ideally, they would make the arrangements and pay, but at the very least they should pay), since they’re the ones that disable this bike on the road. Link to comment
Agboett Posted August 24, 2023 Author Share Posted August 24, 2023 Update -- all has been replaced including the rim -- thanks for all the feedback 2 Link to comment
Agboett Posted August 25, 2023 Author Share Posted August 25, 2023 They covered it all -- they did say they did not think it was pads on one side as someone suggested, I did not press as they were forthright & accomadating 2 Link to comment
