JZ67 Posted July 13, 2023 Share Posted July 13, 2023 Hey again. So far I'm loving my 06 RT and just enjoying the seat time I can get. Playing with the radio buttons I come across a setting for aux but can't find the aux outlet. Is there one that I'm missing or is the radio capable of an aux outlet that needs to be installed. Thanks in advance for the help JZ67 Link to comment
DJDixon Posted July 14, 2023 Share Posted July 14, 2023 It should be in the right hand fairing pocket with the factory stereo unit, either loose or fastened to the plastic cover from below. Looks like a small stereo headphone jack. That's the Aux input. That's where it was in my '06, anyway. Link to comment
SHIMHEAD Posted July 14, 2023 Share Posted July 14, 2023 JZ67, If I remember correctly, there was an available sub-harness that could be purchased from BMW that plugged into the CD/Radio that gave you the Aux input jack. Maybe check on www.realoem.com to see if it is still listed/available. If not, I'm also pretty sure that the CD/Radio unit was also used in BMW cars (3 Series most likely in the same year range), so the same part might be available from a BMW car dealer. Link to comment
