gmcjetpilot Posted June 25, 2023 Share Posted June 25, 2023 There was an old thread that is 6 yrs old, last post 3 yrs ago. Starting a new thread about what filter you use, where you buy, cost and wrench you use. My 74mm plastic wrench slipped on my new Bosch 72161 filter. I ended up buying PN# W54108 Performance Tool Cap Filter Wrench: Fits 73 mm 14 Flute. Fit perfect. I don't recall what filter I used last time. I did not try new wrench on old filter. I know this is a common issue, oil filter wrench slip. Here is a list I have collected from many sources. I did not verify the bypass pressure (1.5 bars / 21.7psi). I assume the first 4 are within form, fit, function specs. BMW 11 42 1 460 845 Bosch 72161 , 3330 Mahle OC91 MANN W712/38 Other unverified AC DELCO: PF-53 AMSOIL: SMF-122? BMW 11 42 1 460 697 BMW 11 42 1 460 858 BMW 11 42 2 325 751 Bosch 3312 Caltric AH8859FL138JU Champion Laboratories PH7025 EMGO 10-26720 Fram PH-3614 Fram PH-6063 Hastings: 157A, LF157 Hiflo HF-163 K&N KN-163 (has 17 mm sheet metal nut tack welded on bottom for wrenching, eliminating slipping oil wrench issue) LUBER-FINER PH2835 LUBER-FINER PH7025 Mobil 1 M1 - 102 Mobil 1 M1 - 103 Motorcraft: FL-271, FL-793 NAPA #1348 Purolator ML16825 Purolator: FCO-201, PER-241 SAAB 9144445 STP PH7025 WARNER PH7025 Wix: 51348, 51785, 57936 What wrench do you use with what filter? What filter do you recommend or like and why? What filter do you NOT recommend? Link to comment
Michaelr11 Posted June 25, 2023 Share Posted June 25, 2023 I use the Oilhead filter wrench 11 4 650 from Max BMW. Same wrench, using it for almost twenty years. It has never slipped, and never failed. Mahle OC91, but I buy the OC91D which is identical to the OEM filter kit with the bag of new crush washers. Purchase all my filters from Rock Auto dot com. Usually buy about a year’s supply at one time. Haven’t had any issues, but have stuck with OEM, Mahle. Link to comment
jacksdad63 Posted June 25, 2023 Share Posted June 25, 2023 I had loads of trouble removing the filter when I got my1100RT. I tried 4 removers that were said to be correct size, one was totally wrong and the others either wouldn't grip the filter or just didn't fit in the engine casing. I ended up wrapping emery tape round the removal tool that was the best fit and knocking it over the filter...then it came off very easily. The filter was some obscure brand and poorly made, so the removers just couldn't grip it, without the emery tape. Next time I'll get a K&N filter as they have a socket fitting on the outer centre which will ensure I can get it off without a fight. Link to comment
dirtrider Posted June 25, 2023 Share Posted June 25, 2023 28 minutes ago, jacksdad63 said: I had loads of trouble removing the filter when I got my1100RT. I tried 4 removers that were said to be correct size, one was totally wrong and the others either wouldn't grip the filter or just didn't fit in the engine casing. I ended up wrapping emery tape round the removal tool that was the best fit and knocking it over the filter...then it came off very easily. The filter was some obscure brand and poorly made, so the removers just couldn't grip it, without the emery tape. Next time I'll get a K&N filter as they have a socket fitting on the outer centre which will ensure I can get it off without a fight. Afternoon jacksdad63 Those K&N filters are not all roses either, over the years I have had to help a number of riders remove those darn K&N filters as once they get tight that center nut can break off then they are a real pain to remove. Standard fluted filters are not at all difficult to remove, but before installing make sure that you have a proper tight fitting filter wrench, or take the filter to a local auto parts store & buy a proper fitting filter wrench so you can remove it when the time comes. 1 1 Link to comment
Joe Coastie Posted June 27, 2023 Share Posted June 27, 2023 Another trick I have used throughout the years on both car/trucks and bikes is to drill 3-4 holes in my cup type filter wrench big enough for decent size sheet metal screws to be screwed into the offending filter to prevent the filter wrench from slipping. But the easiest solution is to have the correct filter wrench for the job. Just my 2 cents Link to comment
ADulay Posted June 27, 2023 Share Posted June 27, 2023 Have used an old NAPA strap wrench forever when revoving filters. Takes every filter off of every BMW I've ever owned. AD Link to comment
dirtrider Posted June 27, 2023 Share Posted June 27, 2023 10 minutes ago, ADulay said: Have used an old NAPA strap wrench forever when revoving filters. Takes every filter off of every BMW I've ever owned. Afternoon ADulay Yes, those work pretty good (IF) you can get the strap on the filter. But on BMW engines like the BMW 1150 that is about impossible to do as the filter is recessed. Link to comment
ADulay Posted June 27, 2023 Share Posted June 27, 2023 Aha! Well that changes everything for sure! AD Link to comment
gmcjetpilot Posted June 27, 2023 Author Share Posted June 27, 2023 1 hour ago, ADulay said: Have used an old NAPA strap wrench forever when revoving filters. Takes every filter off of every BMW I've ever owned. AD So what kind wrench. With the filter recessed in a well and plastic fairing no room for my old "strap wrench". You have pic or pn? Link to comment
gmcjetpilot Posted June 27, 2023 Author Share Posted June 27, 2023 12 hours ago, Joe Coastie said: Another trick I have used throughout the years on both car/trucks and bikes is to drill 3-4 holes in my cup type filter wrench big enough for decent size sheet metal screws to be screwed into the offending filter to prevent the filter wrench from slipping. But the easiest solution is to have the correct filter wrench for the job. Just my 2 cents The problem is once you install new filter, remove wrench and wood screws, it will leak oil. Ha ha. Good tip but my problem was tightness of new replacement filter. My recent thread of engine oil leak was traced to my new oil filter. Ir was leaking. I can only guess it was under torqued and got loose and started to drip about 400 miles after oil change. My old wrench with with old filter was OK, not great. New filter fit? Wrench slipped. I shimmed it and got it tight enough to torque it, I thought. Using a new wrench that fit with stubby socket wrench, I removed new filter to check for double gasket. It was too easy to spin off. No double gasket. So I put filter back on and torqued it, no wrench slip. So this was good news. It explained leak. Filter was loose. When it was leaking it was only a few drips, but it was getting worse I think. A good fitting wrench is needed to get good torque. Yes I used a torque wrench and recommended torque the first time... I thought. The ill fitting wrench I think contributed to it being under torqued. May be I did not read the torque wrench right, regardless a good fitting filter wrench is important. All the work arounds (e.g., sand paper wrap around fitler) is less than ideal. I just road 80 miles since I checked filter and re-torqued it. Bike parked for 6 hours. Dip free. Yeah. I will check torque in a few 100 miles. My theory is oil filters are not all the same and no one size wrench fits all brands of filters that is suitable for BMW R1150RT. Also different brands of oil wrenchs are not the same. Stick with OEM brand filter and BMW wrench you are good. OR if you have a wrench and filter combo that works, stick with that combo. This design is a bit odd ball from my experience. Yes I known German Engineering is perfect. My VW automobile has oil filter housing with screw on cap, drop in filter cartridge. I can change oil and filter standing from top (with vacuum oil extraction). Clean and efficient. Doing it from bottom is pain due to jacking car and belly pan and 20 screws. Love oil extraction on the car. Other engines I serviced that use spin on filters, I could access with strap filter wrench. You have to have the right tool for the job as always. Link to comment
RK Ryder Posted June 28, 2023 Share Posted June 28, 2023 13 hours ago, Joe Coastie said: Another trick I have used throughout the years on both car/trucks and bikes is to drill 3-4 holes in my cup type filter wrench big enough for decent size sheet metal screws to be screwed into the offending filter to prevent the filter wrench from slipping. But the easiest solution is to have the correct filter wrench for the job. Just my 2 cents Another less intrusive way of removing a filter that is a bit loose is line the filter wrench with a rag. Link to comment
