Joe Frickin' Friday Posted June 12, 2023 Share Posted June 12, 2023 With space at a premium on a motorcycle, it's smart to buy compact gear. I found a great flashlight this spring, and figured I'd spread the word: https://www.amazon.com/KunHe-Magnetic-Flashlights-Rechargeable-Flashlight/dp/B09NLMQ24D What's good about it? Well, it's compact but bright. Four brightness settings, the brightest being 500 lumens. That's brighter than the Maglite Tac-Lite I've been using for years (while also being smaller). It also charges via USB-C. I already carry a USB charger and USB-C cable for my phone, so I'm all set. I'm guessing you also carry a USB charger; if you don't use USB-C for charging your phone, well, this one comes with a short USB-C cable. An indicator light tells you when it's fully charged. Probably the best feature is all the ways you can position it for use: It's got a built-in carabiner so you can hang it from a belt/jacket loop, or any handy cable/loop on your bike or other object. There's a magnet on the back, so you can stick it to any ferrous object, like a frame bar. There's a four-position kickstand on the backside so you can prop it up on pretty much any surface that it doesn't slide off of. There's a 1/4-20 female thread on the bottom, so you can attach it to a standard C-mount camera tripod (I carry an Ultrapod, which also has a removal phone gripper for selfies) If you're in the market for a flashlight, you'll want to check this one out. 2 Link to comment
Twisties Posted June 12, 2023 Share Posted June 12, 2023 Looks interesting, and a great value. Link to comment
Skywagon Posted June 12, 2023 Share Posted June 12, 2023 Dang it Mitch....I am flashlight junkie so naturally I just ordered them. You put me on to Nightcore about 10 years ago. It is still my favorite light. I can't believe how bright it is. 1 Link to comment
Joe Frickin' Friday Posted June 12, 2023 Author Share Posted June 12, 2023 55 minutes ago, Skywagon said: You put me on to Nightcore about 10 years ago. It is still my favorite light. I can't believe how bright it is. I googled nightcore and got this: https://en.wikipedia.org/wiki/Nightcore I'm guessing you mean something else? Link to comment
lkraus Posted June 12, 2023 Share Posted June 12, 2023 https://www.nitecorestore.com/ Link to comment
Yuro Posted September 4, 2023 Share Posted September 4, 2023 On 6/12/2023 at 8:36 AM, Joe Frickin' Friday said: With space at a premium on a motorcycle, it's smart to buy compact gear. I found a great flashlight this spring, and figured I'd spread the word: https://www.amazon.com/KunHe-Magnetic-Flashlights-Rechargeable-Flashlight/dp/B09NLMQ24D What's good about it? Well, it's compact but bright. Four brightness settings, the brightest being 500 lumens. That's brighter than the Maglite Tac-Lite I've been using for years (while also being smaller). It also charges via USB-C. I already carry a USB charger and USB-C cable for my phone, so I'm all set. I'm guessing you also carry a USB charger; if you don't use USB-C for charging your phone, well, this one comes with a short USB-C cable. An indicator light tells you when it's fully charged. Probably the best feature is all the ways you can position it for use: It's got a built-in carabiner so you can hang it from a belt/jacket loop, or any handy cable/loop on your bike or other object. There's a magnet on the back, so you can stick it to any ferrous object, like a frame bar. There's a four-position kickstand on the backside so you can prop it up on pretty much any surface that it doesn't slide off of. There's a 1/4-20 female thread on the bottom, so you can attach it to a standard C-mount camera tripod (I carry an Ultrapod, which also has a removal phone gripper for selfies) If you're in the market for a flashlight, you'll want to check this one out. ...and finally, it'll open a beer. 1 Link to comment
