Kurt Haagh Posted May 30, 2023 Share Posted May 30, 2023 2 years ago I had a Tripteq Heeler sidecar installed on my r1100rt with 40K. and it works! A gap has now appeared in the bearing in the steering column. Are there instructions on how to replace this bearing? Link to comment
dirtrider Posted May 30, 2023 Share Posted May 30, 2023 1 hour ago, Kurt Haagh said: 2 years ago I had a Tripteq Heeler sidecar installed on my r1100rt with 40K. and it works! A gap has now appeared in the bearing in the steering column. Are there instructions on how to replace this bearing? Afternoon Kurt The BMW 1100RT doesn't have a steering column, are you referring to replacing the ball thrust bearing in the upper fork bridge? Link to comment
Kurt Haagh Posted May 31, 2023 Author Share Posted May 31, 2023 Yes! Apparently my technical English could be betterr.... Link to comment
dirtrider Posted May 31, 2023 Share Posted May 31, 2023 2 hours ago, Kurt Haagh said: Yes! Apparently my technical English could be betterr.... Morning Kurt Check your PM (Personal Messages) on this site as I sent you some info on replacing the upper fork bridge bearing. Any questions on that just ask____ Link to comment
