009jim Posted May 28, 2023 Share Posted May 28, 2023 Folks, I'd like to know what people do to prevent the rear wheel from rotating when you want to torque up the bolts, or undo the bolts? I am referring to the bolts which fasten the wheel to the final drive. Link to comment
Danny caddyshack Noonan Posted May 28, 2023 Share Posted May 28, 2023 Board under the front tire to make the wight go on the rear. In gear and torque downward to apply more weight. Edit: I seem to recall using another board or extension handle to activate the rear brake somehow. Mental hard drive is defragmenting now. 1 Link to comment
wbw6cos Posted May 28, 2023 Share Posted May 28, 2023 I usually have my yard work boots on and end up using those to assist in chocking the wheel as I sit on the shop floor. Not the best way, but it works for me. 1 Link to comment
Hati Posted May 29, 2023 Share Posted May 29, 2023 Just use a higher gear like 5 or 6. No need for brakes. Link to comment
dirtrider Posted May 29, 2023 Share Posted May 29, 2023 15 hours ago, 009jim said: Folks, I'd like to know what people do to prevent the rear wheel from rotating when you want to torque up the bolts, or undo the bolts? I am referring to the bolts which fasten the wheel to the final drive. Morning 009jim Depends, I usually put trans in 1st gear with the rear wheel on the ground then break them loose before lifting the wheel off the ground (or off my motorcycle lift table). As for torquing them after wheel install, I usually tighten by hand (no torque wrench) then after returning from first ride I leave the trans in 1st gear with rear wheel on the ground then torque them, or at least re-check to verify they are still tight. With alloy wheels & tapered-seat bolts they should have a verification check after the first ride anyhow. 1 Link to comment
009jim Posted June 4, 2023 Author Share Posted June 4, 2023 On 5/29/2023 at 8:33 AM, 009jim said: Folks, I'd like to know what people do to prevent the rear wheel from rotating when you want to torque up the bolts, or undo the bolts? I am referring to the bolts which fasten the wheel to the final drive. Since posting this query, I found there is a very informative Youtube video. Link to comment
