Dingo55 Posted May 24, 2023 Share Posted May 24, 2023 I see that the 1250 riders manual calls for sintered pads front and rear Is that a missprint? The 1200 calls for sintered front and organic rear My front callipers are BMW while the rear are Brembo Any reason for that Just curious Cheers Mark Link to comment
Cap Posted May 24, 2023 Share Posted May 24, 2023 There was a recall on the front calipers. It sounds like your front calipers are the original Hayes calipers with “BMW” showing on the sides. My 2019 RT had the recall performed, and the replacement calipers are Brembo like the earlier bikes. I am not sure why the spec for the rear pads was changed. Cap Link to comment
dirtrider Posted May 24, 2023 Share Posted May 24, 2023 10 hours ago, Dingo55 said: I see that the 1250 riders manual calls for sintered pads front and rear Is that a missprint? The 1200 calls for sintered front and organic rear My front callipers are BMW while the rear are Brembo Any reason for that Just curious Cheers Mark Afternoon Mark 1200 what, 1250 what? My parts manual calls for sintered on the front and rear on the 1250RT. Some of the 1200 hexhead bikes (like the 1200R called for organic rear but the 1200 hexhead called for sintered on the front and rear. We need to look the brake pads up for your specific motorcycle to tell you more. Link to comment
Dingo55 Posted May 24, 2023 Author Share Posted May 24, 2023 Thanks for the help Much appreciated Sorry My bikes are a 2015 R1200RT and a 2020 R1250RT (only purchased the 1250 3 weeks ago) Regards the caliper recall is that an automatic worldwide thing or does bmw wait to see who screams the loudest? What was the reason for the recall? My 1250 is about to come out of it's 3 year warranty period As far as I can ascertain the bike has only had a pre delivery check and a service at 1K kms Any known reason why the call now for sintered on the rear of the 1250? Thanks again Cheers Mark Link to comment
Etienne Lau Posted May 24, 2023 Share Posted May 24, 2023 My 2010 R1200RT calls for sintered both front and rear. Link to comment
dirtrider Posted May 25, 2023 Share Posted May 25, 2023 14 hours ago, Dingo55 said: Thanks for the help Much appreciated Sorry My bikes are a 2015 R1200RT and a 2020 R1250RT (only purchased the 1250 3 weeks ago) Regards the caliper recall is that an automatic worldwide thing or does bmw wait to see who screams the loudest? What was the reason for the recall? My 1250 is about to come out of it's 3 year warranty period As far as I can ascertain the bike has only had a pre delivery check and a service at 1K kms Any known reason why the call now for sintered on the rear of the 1250? Thanks again Cheers Mark Morning Mark The brake recall was a safety recall so that is automatic, but the letter usually goes out to the owner of record so it might not have been sent to you. (or it has already been done) Call your BMW dealer & give them your VIN to see if there are any outstanding recalls on your motorcycle. The reason for the recall was front calipers seeping (leaking) fluid. On your brakes, on the 1200RT & 1250RT the rear pads are sintered. My BMW parts book shows them as sintered, my guess is that your 2015 R1200RT riders manual is a misprint, or possibly a last minute change in production that didn't make it into the riders manual. Link to comment
Hati Posted May 25, 2023 Share Posted May 25, 2023 9 hours ago, dirtrider said: Call your BMW dealer & give them your VIN to see if there are any outstanding recalls on your motorcycle. Or if my suspicion is correct and Mark is from the land of Oz, he could just plug his VIN into the following page: https://recall.bmw.com.au Link to comment
Dingo55 Posted May 25, 2023 Author Share Posted May 25, 2023 Hi all Appreciate the help I did ring the dealer yesterday and they were certain that there is no recalls outstanding on the bike only a computer 'thingy' (my tech word) upgrade to be done Thanks Hati I ran the numbers through the site and all clear So Did the calliper problem only apply to a certain batch? How widespread was/is it? I don't actually have a copy of the riders manual (still waiting) This is from a computer 'thingy' (great word) that I was directed to Page 162 lists the rear as organic Why has that changed? I thought there was a reason to not run sintered on the rear Anyhow all good Thanks again Cheers Mark Link to comment
Wayne Johnson Posted May 26, 2023 Share Posted May 26, 2023 The recall I believe was only on the 2019 models with the Hayes calipers. Apparently the leaky calipers was more due to lack of use not a problem in my case as my Hayes are continuing to preform without issue. I will have the recall done once pads are needed which will probably be this fall as the original pads are still good at 40k Link to comment
Dave_in_TX Posted May 26, 2023 Share Posted May 26, 2023 1 hour ago, Wayne Johnson said: The recall I believe was only on the 2019 models with the Hayes calipers. Apparently the leaky calipers was more due to lack of use not a problem in my case as my Hayes are continuing to preform without issue. I will have the recall done once pads are needed which will probably be this fall as the original pads are still good at 40k The recall also included 2020 models. Link to comment
dirtrider Posted May 26, 2023 Share Posted May 26, 2023 22 hours ago, Dingo55 said: Hi all Appreciate the help I did ring the dealer yesterday and they were certain that there is no recalls outstanding on the bike only a computer 'thingy' (my tech word) upgrade to be done Thanks Hati I ran the numbers through the site and all clear So Did the calliper problem only apply to a certain batch? How widespread was/is it? I don't actually have a copy of the riders manual (still waiting) This is from a computer 'thingy' (great word) that I was directed to Page 162 lists the rear as organic Why has that changed? I thought there was a reason to not run sintered on the rear Anyhow all good Thanks again Cheers Afternoon Mark I'm not sure the rear pad material was changed, I think it was more of a mis-print or the OEM factory pad requirement was changed after the manual was printed. Just remove the rear pads then give us the numbers that are on the pads, we can then (hopefully) tell you what you have. 1 Link to comment
Geekmaster Posted May 27, 2023 Share Posted May 27, 2023 For what it's worth, here's a snippet from the 2014 R1200RT rider's manual, which you can download from BMW's site. It still specifies organic pads. for the rear brake. Link to comment
dirtrider Posted May 27, 2023 Share Posted May 27, 2023 11 hours ago, Geekmaster said: For what it's worth, here's a snippet from the 2014 R1200RT rider's manual, which you can download from BMW's site. It still specifies organic pads. for the rear brake. Morning Geekmaster But the riders manual doesn't give us part numbers. The BMW parts manual does give us part numbers & pad type, plus the BMW parts manual is current, the riders manual was printed long ago. 34218562163 set of brake pads, SINTERED METAL. Link to comment
Skywagon Posted May 27, 2023 Share Posted May 27, 2023 You can use organic, but....your wheels will be filthy after a ride with brake dust and you will end up changing them out at least twice as often. They also fade under continuous heavy braking. I have a 2014 bought new. The factory pads went about 10,000 miles. The EBC semi's have been on about 20,000 and are still in good shape. When I changed out the organic's it took a lot of effort to get the embedded material off the rotors. Link to comment
Geekmaster Posted May 27, 2023 Share Posted May 27, 2023 Thanks, @Skywagon, that's helpful. I have 15k on my factory original rear pads, but it looks like I will need to change them later this summer, so I bought some Brembo Carbon Ceramic pads that Brembo specified. Once I put them on later, I'll see how they work, compared to the originals. Link to comment
Geekmaster Posted May 27, 2023 Share Posted May 27, 2023 8 hours ago, dirtrider said: Morning Geekmaster But the riders manual doesn't give us part numbers. The BMW parts manual does give us part numbers & pad type, plus the BMW parts manual is current, the riders manual was printed long ago. 34218562163 set of brake pads, SINTERED METAL. Thanks, Dirtrider, makes sense. Link to comment
Dingo55 Posted May 28, 2023 Author Share Posted May 28, 2023 Hi all Appreciate the help My local(ish) BMW parts supplier has 3 options for rear brake pads for 2015 r1200rt 1. organic 2. kevlar & 3. fully sintered So it's lucky dip time Tried the kevlars last time 8,600 kms toasted Maybe if I didn't go so fast hmm Can't make out any numbers Cheers Mark Link to comment
