Taifighter Posted May 23, 2023 Share Posted May 23, 2023 As the title says, I have a very loose brake lever on my 96 r1100r the screw on the end of it is also barely but when I tighten it it grabs on the wheel tighter. What’s the best course of action here IMG_0083.mov Link to comment
dirtrider Posted May 23, 2023 Share Posted May 23, 2023 1 hour ago, Taifighter said: As the title says, I have a very loose brake lever on my 96 r1100r the screw on the end of it is also barely but when I tighten it it grabs on the wheel tighter. What’s the best course of action here IMG_ Afternoon Taifighter I can't tell for sure until you take it apart but something is really loose or broken. It could be a missing or destroyed lever pivot bushing, or a broken pivot bolt, or a very loose pivot bolt in conjunction with a worn bushing. In any case you need to address it before the lever falls completely off then you have no front brake. Link to comment
Taifighter Posted May 23, 2023 Author Share Posted May 23, 2023 3 hours ago, dirtrider said: Afternoon Taifighter I can't tell for sure until you take it apart but something is really loose or broken. It could be a missing or destroyed lever pivot bushing, or a broken pivot bolt, or a very loose pivot bolt in conjunction with a worn bushing. In any case you need to address it before the lever falls completely off then you have no front brake. Thanks for the reply, would a rebuild kit for the master cylinder kit include the lever pivot? And the the bushing are very much gone Link to comment
dirtrider Posted May 24, 2023 Share Posted May 24, 2023 12 hours ago, Taifighter said: Thanks for the reply, would a rebuild kit for the master cylinder kit include the lever pivot? And the the bushing are very much gone Morning Taifighter Probably not, depends on who put the kit together but I seriously doubt it would include those parts. The parts are available from BMW. P/N ___ 32722310753 screw__ $36.80 P/N___ 32722310754 bushing__ $8.36 Link to comment
Taifighter Posted May 24, 2023 Author Share Posted May 24, 2023 1 hour ago, dirtrider said: Morning Taifighter Probably not, depends on who put the kit together but I seriously doubt it would include those parts. The parts are available from BMW. P/N ___ 32722310753 screw__ $36.80 P/N___ 32722310754 bushing__ $8.36 Good morning! beemerboneyard has a rebuild kit and I’ll just grab those bmw. I should replace the brake lines while I’m at it. Any recommendations? Link to comment
Brodiepunker18 Posted May 24, 2023 Share Posted May 24, 2023 Galfer lines are good lines. I put those on my RT last spring Link to comment
9Mary7 Posted May 25, 2023 Share Posted May 25, 2023 Spiegler are another good option for brake lines. Link to comment
