Twisties Posted May 18, 2023 Share Posted May 18, 2023 The thing being, I've only ever had to repair a flat on the road once, and it worked. But, at home, when I check my kit, I often find the glue/adhesive included with tire repair kits has dried out and is unusable, even though it has never been opened. I supposed the tube gets battered over the years. Maybe I should put it in a little container? What is your strategy or product for being sure you have a functional tire repair kit, or do you just carry a credit card? Where do you get replacement glue without having to buy a whole kit? Link to comment
dirtrider Posted May 18, 2023 Share Posted May 18, 2023 1 hour ago, Twisties said: The thing being, I've only ever had to repair a flat on the road once, and it worked. But, at home, when I check my kit, I often find the glue/adhesive included with tire repair kits has dried out and is unusable, even though it has never been opened. I supposed the tube gets battered over the years. Maybe I should put it in a little container? What is your strategy or product for being sure you have a functional tire repair kit, or do you just carry a credit card? Where do you get replacement glue without having to buy a whole kit? Morning Twisties I replace the glue often, every couple of months, or even sooner if I think of it. That glue doesn't like heat so that is one of the failure factors. I just buy a small tube from an auto parts store. I either put the glue in a double small zip-loc bag or if I have the time & thought I use a food vacuum sealer to remove the air from around the glue tube. Once opened I replace as soon as possible (if I wait to replace then I typically forget to replace it) Link to comment
MikeB60 Posted May 18, 2023 Share Posted May 18, 2023 Neeley. They work great and no glue necessary. 1 1 Link to comment
duckbubbles Posted May 19, 2023 Share Posted May 19, 2023 I carry a Stop&Go kit with included electric pump that uses pre-lubed mushroom plugs, no glue required. Had to use it twice and happy to report that the tires held air as well as before the puncture. Frank Link to comment
marcopolo Posted May 19, 2023 Share Posted May 19, 2023 I replace the ropes, and the glue, on at least a yearly basis. I pick them up at an auto supply store. 2 Link to comment
ADulay Posted May 19, 2023 Share Posted May 19, 2023 On the last two tire plugs a didn’t use the “glue”, just the black ropes and they held up just fine. AD 1 Link to comment
dduelin Posted May 26, 2023 Share Posted May 26, 2023 I replace the tubes each spring or after 1 use in the kits in each of my road going bikes. Using gummy worms the glue acts as a lubricant when inserting the tool with the plug. 1 Link to comment
