KBoot Posted May 7, 2023 Share Posted May 7, 2023 Hi, Anyone know the type and size for the drain plug on a 2011 1200rt? Its a female insert type of plug and the outside is round. I believe it hold 4 quarts right? Thanks! Link to comment
Etienne Lau Posted May 9, 2023 Share Posted May 9, 2023 Not sure what you're asking. Are you looking to replace the existing drain plug? But the last time I did oil change, I used an 8mm hex on it. And no it's not 4 QTS, to be precise is 4L/4.23 QT. Link to comment
