James Gay Posted April 27, 2023 Share Posted April 27, 2023 Having trouble getting the inner plastic piece with the new o-ring seated back in place. Link to comment
BABABeemer Posted April 28, 2023 Share Posted April 28, 2023 I smeared a little RTV Silicone inside to lubricate it going in. Link to comment
James Gay Posted April 28, 2023 Author Share Posted April 28, 2023 What is the RTV part? Silicone grease? Silicone spray? Sorry to be such a dummy. Link to comment
Jim Moore Posted April 28, 2023 Share Posted April 28, 2023 I use a little oil on the o-ring, then tapped it into place with an appropriately sized socket. Link to comment
dirtrider Posted April 28, 2023 Share Posted April 28, 2023 On 4/27/2023 at 7:48 PM, James Gay said: Having trouble getting the inner plastic piece with the new o-ring seated back in place. Morning James I usually use a little motor oil or sometimes assembly lube. Some of them can be a bit difficult to push or tap in. If you use anything containing silicone, like silicone grease or spray just make darn sure that it is o2 safe as silicone in an engine can ruin your o2 sensor. Also remember, the easier it goes in the easier it can pop out on it's own as the BMW boxer engines have fairly high internal pressure swings due to the Boxer piston travel design Link to comment
BABABeemer Posted May 2, 2023 Share Posted May 2, 2023 On 4/27/2023 at 8:28 PM, James Gay said: What is the RTV part? Silicone grease? Silicone spray? Sorry to be such a dummy. Good morning James, The RTV Silicon I mentioned is a Room Temperature Vulcanizing adhesive that helps gaskets seal. It takes about a half hour to set up properly. The reason I don’t use oil on the o ring is because it can pop out as crankcase pressure builds and give you a shower of hot oil! Not fun! It comes in tubes of black, red, and blue and one color is oxygen sensor safe, but I don’t remember which one since I don’t use the oxygen sensor. Link to comment
