gmcjetpilot Posted April 24, 2023 Share Posted April 24, 2023 About to put pump/filter Assy back, doing final clean and inspection. I see blisters and holes. 😳. There is an expensive aerospace fuel proof bonds like steel epoxy called PRO SEAL. It likes it was made like this. I'm in holding pattern before I assemble. Is this OK Link to comment
dirtrider Posted April 24, 2023 Share Posted April 24, 2023 Afternoon gmcjetpilot It is difficult to tell much from the pictures but it looks odd. I have seen some bubbling that didn't really cause any issues but that just looks a bit different. Are you SURE that (epoxy anything) will stick to, & stay adhered, to that surface? Link to comment
man1nvan Posted April 24, 2023 Share Posted April 24, 2023 I replaced my tank last year, the new one had a few (not as many as yours) bubbles like that inside. really rough on the outside too i assumed this was just a crude hidden part on these bikes Link to comment
Skywagon Posted April 24, 2023 Share Posted April 24, 2023 ProSeal is amazing. I’ve lined many aluminum tanks with it. It is darn near bullet proof. I’ve never seen it used on plastic or whatever our tanks are made from. You might write or call them to be sure it will seal on these tanks Link to comment
gmcjetpilot Posted April 25, 2023 Author Share Posted April 25, 2023 22 hours ago, dirtrider said: Afternoon gmcjetpilot It is difficult to tell much from the pictures but it looks odd. I have seen some bubbling that didn't really cause any issues but that just looks a bit different. Are you SURE that (epoxy anything) will stick to, & stay adhered, to that surface? I have a background in composites. These tanks look like they have a plastic honeycomb core and inner and outer looking at the one big blister hole that was OPEN. It is not leaking. It did not feel heavy when tank was off and stripped of parts, but then again I don't know what a stock one would feel like. My point is did feel "water logged" with gas. I put it together, put in bike for test fit. I COULD NOT resist, I put fuel in and IT STARTED RIGHT UP... with all the proper fuel indications (low fuel and level). I am not going to worry about it. I suspect this is manufacturing defect may be made worse by ethanol? Link to comment
dirtrider Posted April 25, 2023 Share Posted April 25, 2023 16 minutes ago, gmcjetpilot said: I have a background in composites. These tanks look like they have a plastic honeycomb core and inner and outer looking at the one big blister hole that was OPEN. It is not leaking. It did not feel heavy when tank was off and stripped of parts, but then again I don't know what a stock one would feel like. My point is did feel "water logged" with gas. I put it together, put in bike for test fit. I COULD NOT resist, I put fuel in and IT STARTED RIGHT UP... with all the proper fuel indications (low fuel and level). I am not going to worry about it. I suspect this is manufacturing defect may be made worse by ethanol? Afternoon gmcjetpilot That is probably your best bet, if it is going to turn into a problem then it will more than likely start smelling of gasoline vapors with no real leak present. If the tank starts getting to that point then hydrocarbons are probably starting to wick through the outer layer. Link to comment
Keith S Posted May 1, 2023 Share Posted May 1, 2023 I was just looking in my tank 2004 R1150RT and saw the same thing. Looks like bubbles rose up in the plastic while curing. I'm not going to worry about it either. Keith Link to comment
