Dirtmerchant Posted April 24, 2023 Share Posted April 24, 2023 Hey guys and gals. Getting ready for a week long trip and I need some help, I have the following: 2018 RT with Audio, recent dealer updates if that changed anything Sena 50S with 1.2.2 firmware (most recent) Nav VI with updates. iPhone 13Pro with iOS 16.4.1 I want to be able to listen to Media from the iPhone through the Nav VI to the Sena OR switch the Audio on the bike and listen to XM or FM to the Sena; also want to be able to make calls through the Nav VI to the Sena. I can get each one to work but not seamlessly and I know it can be done. Can anyone tell me specifically which profile each device should be paired to the other? NOW iPhone 13 to Nav VI - PHONE PAIRING 4.1.2 in the manual Nav VI to Sena 50S - GPS PAIRING 4.4 in the manual RT to Sena 50S - MEDIA SELECTIVE PAIRING - A2DP Profile 4.3.2 in the manual I DO NOT have the iPhone 13 connected to the Sena 50s Thank you!! Link to comment
Skywagon Posted April 24, 2023 Share Posted April 24, 2023 DirtMerchant...I can't. Not that smart. If no one here has the info, reach out to these folks. They have a series of videos that show how to connect various SENA's to Iphone to BMW. I have mine hooked up via one of their videos and it works as it is suppose to. Richard and Kathy are nice people and also make some nice products. Home - RKA Motorcycle Luggage (rka-luggage.com) No affiliation at all. 1 Link to comment
Octane Posted April 25, 2023 Share Posted April 25, 2023 Here's the link to the video I used: BMW K1600GTL / GT / R1200RT Bluetooth connections Link to comment
Skywagon Posted April 25, 2023 Share Posted April 25, 2023 Dirtmerchant....this is the video I use to connect mine. Some of the button pushing might be different on your unit, but the principle should be the same on what you connect. Link to comment
Dirtmerchant Posted April 26, 2023 Author Share Posted April 26, 2023 Thanks, I agree that Richard is the most help in the Sena world. I'm not sure where it went wrong, most likely user error. I initially but I had my Apple Watch on and connected to my iPhone when I did the initial set up so perhaps that contributed. The following is what I did that is currently working. Devices - 2018 BMW R12RT with Audio, BMW Nav VI, Sena 50s Update all firmware on Sena, Nav and iPhone. Delete all pairing from RT, Sena, Nav and forget related devices on the iPhone, I did a factory reset on the Sena but don't know if it is necessary Remove any unrelated connected bluetooth devices from the scene, in my case I shut down my Apple Watch Turn on the Sena headset 1st Sync Sena to the RT using Phone Pairing Profile as described in 4.1.2 of Sena manual 2nd Sync Sena to Nav using 2nd Mobile Phone Pairing Profile as described in 4.2 of the Sena manual 3rd Pair the iPhone to the Nav - obviously no Sena profiles I can listen to media on the micro card in my NAV, listen to media from my iPhone (Pandora) through the Nav and listen to media (FM) from the RT and switch around reliably. Link to comment
Skywagon Posted April 26, 2023 Share Posted April 26, 2023 Your watch probably was a problem. The last time I did mine it wasn’t working. I had my iPad in the garage and that was the issue. 1 Link to comment
