MikeB60 Posted April 20, 2023 Share Posted April 20, 2023 Saw this on the K1600 site. Link Link to comment
wbw6cos Posted April 20, 2023 Share Posted April 20, 2023 I saw that earlier. Nice. I wonder if it still fits the Nav VI adapter made in Italy. https://www.rideapart.com/news/663219/garmin-zumo-xt2-motorcycle-navigation/ explains what is new. Link to comment
BamaJohn Posted April 21, 2023 Share Posted April 21, 2023 9 hours ago, MikeB60 said: Saw this on the K1600 site. Link This is so typical...this.dumbass hasn't learned everything about my Zumo XT yet, and a new, improved model is out...I can't keep up on technological gadgets like GPS; cell phones; computers; motorcycle systems; comm units; microwave ovens; washing machines....on and on. I just learned how to descale my Keurig coffeemaker! 3 2 Link to comment
TEWKS Posted April 21, 2023 Share Posted April 21, 2023 4 hours ago, BamaJohn said: I just learned how to descale my Keurig coffeemaker! John, could you please post a tutorial? Heck, I’ve almost got my Nav IV mastered, it may just be time to move up! 1 1 Link to comment
RTinNC Posted April 21, 2023 Share Posted April 21, 2023 16 hours ago, wbw6cos said: I saw that earlier. Nice. I wonder if it still fits the Nav VI adapter made in Italy. https://www.rideapart.com/news/663219/garmin-zumo-xt2-motorcycle-navigation/ explains what is new. I was wondering the same ! Also, they can make a new version of the XT but can't get the Nav6 right! 1 Link to comment
Chris K Posted April 23, 2023 Share Posted April 23, 2023 According the announcement I read, the XT2 will fit in the samt mount as the XT. The wiring harness that you screw into the mount may be differerent. Link to comment
wbw6cos Posted April 23, 2023 Share Posted April 23, 2023 Yeah, I guess I should have actually read the article in the link that I posted. Thanks!! Link to comment
lkraus Posted April 23, 2023 Share Posted April 23, 2023 1 hour ago, Chris K said: According the announcement I read, the XT2 will fit in the samt mount as the XT. The wiring harness that you screw into the mount may be differerent. It fits, but Garmin says it may be a bit loose. More importantly, Garmin does not use the XT 12V to 5V converter box on the XT2 wiring harness. Although the XT2 will power up and work with either voltage, it will not charge as quickly on an XT mount. I suspect an XT will not work and may be damaged in an XT2 mount. "Current zūmo XT customers that are upgrading to the zūmo XT2 and are NOT using the Group Ride Radio, may use the zūmo XT mount and wiring. However, this configuration will limit how quickly the zūmo XT2 will charge. This is because the zūmo XT default power cable only provides 1.5A (7.5W). The power cables provided with the zūmo XT2 are rated for higher voltage/power (12V/24W) and are easier to install as they can be cut to length. Garmin recommends installing the mount and power cables provided with the zūmo XT2 for peak performance." Link to comment
