KDeline Posted April 18, 2023 Share Posted April 18, 2023 2009 R 1200 RT 46,000 miles. So occasionally for the past year about once a ride, my rear brake pedal will just drop when I apply the brakes with no pressure bottoming out. I’ll pull my foot off quickly and reapply and it works. Obviously if I get in a bad situation that could be dangerous. This was the error code that popped up on the 911 after I did the brake bleed down after the annual bleeding of the brakes. If I cycled the key, the faults were no longer, present, I could clear them, but when I did the brake bleed down a second and third time they would come back. It looks like I have a bad rear sensor, is it something I can replace? I don’t even know where it’s at. Link to comment
MikeB60 Posted April 20, 2023 Share Posted April 20, 2023 Pretty sure that is the kiss of death for the pump. If I'm not mistaken those sensors are internal to the pump and not replaceable. I would call module masters and discuss the issue with them. Link Link to comment
KDeline Posted April 20, 2023 Author Share Posted April 20, 2023 1 minute ago, MikeB60 said: Pretty sure that is the kiss of death for the pump. If I'm not mistaken those sensors are internal to the pump and not replaceable. I would call module masters and discuss the issue with them. Link Ugh. I hope not. I'm stunned no one else has chimed in. Link to comment
