bhulse Posted April 16, 2023 Share Posted April 16, 2023 BLACK 1999 BMW R1100RT $4,200.00 49,963mi Electric adjust wind screen ABS brakes Heated hand grips Maintenance, modifications and additions MAINTENANCE: (Dte/Mileage) Fork seals, dust caps, oil 03/2020 43,200mi Engine Oil/filter, gear box & final drive 03/2022 48,600mi Brake bleed 01/2022 48,500mi Air Filter (K&N) permanent 01/2022 48,500mi Valve adj/rocker arm end-play 08/2020 44,600mi Throttle body sync 08/2020 44,600mi Fuel filter & in tank hoses 08/2015 34,200mi Adj clutch cable end-play 08/2020 44,600mi Adj throttle enricher (choke cable) 08/2020 44,600mi BBS cleaning 08/2020 44,600mi Spark plugs 01/2022 48,500mi Alternator belt 04/2021 46,500mi Tires/valve stems 06/2020 44,500mi Brake pads 01/2022 48,500mi Front Rotors & Buttons (approx) 00/2016 38,000mi Rear Rotor 01/2020 43,000mi Battery 12/2019 42,900mi Clutch cable (approx) 00/2016 38,000mi Throttle cable (approx) 00/2016 38,000mi Starter motor removed/cleaned & lubricated 03/2020 43,200mi MODIFICATIONS/ADDITIONS Kisan Signal Minder directional signal self-cancelling /running light relay ALL LED lamps (except the ‘ALT’ dash lamp which MUST remain an incandescent!) Brake lamp w/decaying stop module Chrome plated brass fuel line quick disconnects Left cam chain tensioner upgrade AF-Xied O2 Sensor manipulator (fuel manager) New ‘TILLS’ certified & balanced 1200 fuel injectors Bosch O2 sensor HES rewire ‘Dimple’ magnetic drain plugs, crankcase, gearbox & final drive ‘Canisterectomy’ (removal of charcoal fuel evaporation canister) Removal of restrictive oil cooler air ducts MOTOREFLECTIVE black reflective panels on trunk and saddlebags Top trunk passenger back rest cushion Handlebar heated grip hi/low indicator lamps ‘CAT’ O-ring throttle lock (cruise control) Saddle bag mats Braided steel brake hoses (Spiegler) Custom BMW roundel on rear mud flap Battery maintainer ADDITIONAL ITEMS TO BE ON THE BIKE WHEN IT IS SOLD OEM tool roll OEM operators, service booklets 2 Link to comment
