Trevor Mogg Posted April 9, 2023 Share Posted April 9, 2023 Hello All,Im new to this site and need any advice regarding swing arm removal.On the right side swing arm pin,i have removed all the bolts and put a longer bolt in the centre..to give it a good pull to remove it.I havnt got a slide hammer and was hoping this method would work.I have managed to get a bit of movement but its still refusing to come out!Would a long bar hitting it from opposite side inside swing arm do the trick,not sure how much force to use.Any advice from you guys would be much appreciated Link to comment
blalor Posted April 9, 2023 Share Posted April 9, 2023 It’s pretty straightforward. This video for a similar vintage GS gives a nice walkthrough. Link to comment
Trevor Mogg Posted April 10, 2023 Author Share Posted April 10, 2023 Thanks Blalor,The video confirmed that the swingarm pin can be removed by tapping with a bar from opposite side if you havnt got a slide hammer.Thank you,Shogun951. Link to comment
