Twisties Posted April 9, 2023 Share Posted April 9, 2023 Been changing our own tires for forever, but only ever had one bike w/TPM before, and that was a long time ago. I know I saw a thread on here about doing it with the TPM sensor, but I couldn't find it just now. Well, I found some, but not the one I thought I recalled. Remind me, our tpm sensors are near the valve? We should try to remove and mount the tire in that area first to avoid dragging the bead over the sensor? Link to comment
Limecreek Posted April 9, 2023 Share Posted April 9, 2023 1 hour ago, Twisties said: Been changing our own tires for forever, but only ever had one bike w/TPM before, and that was a long time ago. I know I saw a thread on here about doing it with the TPM sensor, but I couldn't find it just now. Well, I found some, but not the one I thought I recalled. Remind me, our tpm sensors are near the valve? We should try to remove and mount the tire in that area first to avoid dragging the bead over the sensor? Correct. They are near the valve and yes, take care not to leverage the bead over them. And most of the BMW valves align parallel to the bead. Adjust as needed. Have fun! Link to comment
szurszewski Posted April 9, 2023 Share Posted April 9, 2023 It's not that big of a deal - the sensor is pretty small and mounted in line with the center rim of the wheel (the "deepest" part), so as long as you're keeping your tools near the rim where the bead seats, you should be fine. Pic below of GS sensor - I stole this from Woody's and they list this sensor for all GSs with TPMS (from the earlier 1200s through your fancy new rides). I break the bead on the opposite side of the valve, and that's about it - as you can see the sensors are designed to not have any edges to catch on the tire while you're working it off/onto the wheel, even if you do spin it and "drag" it along the sensor it should be fine. Link to comment
Twisties Posted April 10, 2023 Author Share Posted April 10, 2023 Skillz! I'm impressed. Didn't have any trouble with the TPM sensor. That was when I found out I need different tooling for my no-mar for the GS wheel and I can't get the "yellow thing" to work. Also, the Dunlop Trailmax Missions are STIFFFFFF!!!! I may have to try the Rougaru approach. Link to comment
Hati Posted April 10, 2023 Share Posted April 10, 2023 1 hour ago, Twisties said: the Dunlop Trailmax Missions are STIFFFFFF!!!! Sun is your friend in this instance ;) I stick the new tyres in the sun before fitting them. Some people, especially in colder climates, even get themselves a tyre warmer to make it easier to fit. 1 3 Link to comment
Twisties Posted April 10, 2023 Author Share Posted April 10, 2023 Thanks, yeah, I left them out for about an hour in the sun! Link to comment
duckhawk64 Posted April 10, 2023 Share Posted April 10, 2023 I like leaving the tire(s), in my suv during a got sunny day, and the go to a friend's after work to change them. Park with the back facing South. Link to comment
Rougarou Posted April 10, 2023 Share Posted April 10, 2023 You gotta bake your tires 1 Link to comment
rounder jim Posted April 25, 2023 Share Posted April 25, 2023 Changing tires in northern Illinois during the winter has always been tough.So I use the oven.Nobody else puts them in the oven? The house only smells like rubber for alittle while and the smoke alarm has never gone off. I kind of like the smell. Reminds me of the drag strip 1 Link to comment
