Alba Posted April 4, 2023 Share Posted April 4, 2023 Drove into work this morning all good, left work this evening and both ABS & ACS lights are constantly on. I tried switching the bike off and on still there. I have a motoscan which I connected, no faults in any modules. Any thoughts? Link to comment
dirtrider Posted April 4, 2023 Share Posted April 4, 2023 3 hours ago, Alba said: Drove into work this morning all good, left work this evening and both ABS & ACS lights are constantly on. I tried switching the bike off and on still there. I have a motoscan which I connected, no faults in any modules. Any thoughts? Evening Alba If both your ABS & ACS lights are on then there should be stored fault code to go with them. I don't use a Motoscan myself as I have worked with some riders that issues getting correct codes with the Motoscan. Any way to get a GS-911 on that motorcycle? If not then maybe try using a wooden stick & a hammer (like a cut-off broom handle) then reach in with that stick and rap on the ABS module a few times. (you might have a stuck ABS motor brush). 1 Link to comment
Alba Posted April 5, 2023 Author Share Posted April 5, 2023 Time for a confession, based on MotorScan not finding any faults I rechecked and I some how I managed to switch off both systems ... all fixed and a portion of humble pie served. Link to comment
Chris K Posted April 6, 2023 Share Posted April 6, 2023 Thankfully most of the time humble pie is the cheapest solution! 1 Link to comment
