Tony J Posted March 24, 2023 Share Posted March 24, 2023 I'm new to BMW ownership. I just purchased a 2013 R1200RT with 30K miles on it. Excellent ride! I was in the garage getting to know the in's and out's and saw a small amount of oil at the bottom of the strut. It appears to be coming from the small hose attached it. I assume it is a vent for the shock. Is this small amount normal or is it time to have it replaced? Link to comment
dirtrider Posted March 24, 2023 Share Posted March 24, 2023 26 minutes ago, Tony J said: I'm new to BMW ownership. I just purchased a 2013 R1200RT with 30K miles on it. Excellent ride! I was in the garage getting to know the in's and out's and saw a small amount of oil at the bottom of the strut. It appears to be coming from the small hose attached it. I assume it is a vent for the shock. Is this small amount normal or is it time to have it replaced? Morning Tony Does this look like your font strut? If so then where is the leak coming from per this picture? Link to comment
Tony J Posted March 24, 2023 Author Share Posted March 24, 2023 Yes, it does look like that strut. It appears that is was on the rubber boot, but that is obviously a wiring connection. I'll have to take a better look at it to see if is from above. Link to comment
dirtrider Posted March 24, 2023 Share Posted March 24, 2023 3 minutes ago, Tony J said: Yes, it does look like that strut. It appears that is was on the rubber boot, but that is obviously a wiring connection. I'll have to take a better look at it to see if is from above. Afternoon Tony Also, check your fork seals as those can seep then oil blows to the rear. Link to comment
