Dingo55 Posted March 5, 2023 Share Posted March 5, 2023 Hi all Any recommendations for a inline connector to facilitate the quick removal of the top box on 2015 r1200rt ie not needing to remove the rear seat Maybe something slimmer than the under the seat oem type How many wires are we dealing with ? Mine has the brake light option Anybody felt the need to put a carry handle on their top box If so what did you use? Cheers Mark Link to comment
MikeB60 Posted March 6, 2023 Share Posted March 6, 2023 1 hour ago, Dingo55 said: Hi all Any recommendations for a inline connector to facilitate the quick removal of the top box on 2015 r1200rt ie not needing to remove the rear seat Maybe something slimmer than the under the seat oem type How many wires are we dealing with ? Mine has the brake light option Anybody felt the need to put a carry handle on their top box If so what did you use? Cheers Mark Mark, There are six wires in the connector for my top box. No brake light but I suspect the connector is wired for it. Pic is of a connector I have in my toolbox with 6 wires. The top box already has a carrying handle little confused what you are looking for? Link to comment
Dingo55 Posted March 6, 2023 Author Share Posted March 6, 2023 thanks Now I'm confused There's a handle? Cheers Mark Link to comment
MikeB60 Posted March 6, 2023 Share Posted March 6, 2023 When you turn the key to the Release position, the carrying handle pops up. Link to comment
wbw6cos Posted March 6, 2023 Share Posted March 6, 2023 On the 49 L topcase? Side cases do. Pictures? Link to comment
dirtrider Posted March 6, 2023 Share Posted March 6, 2023 12 hours ago, MikeB60 said: Mark, There are six wires in the connector for my top box. No brake light but I suspect the connector is wired for it. Pic is of a connector I have in my toolbox with 6 wires. The top box already has a carrying handle little confused what you are looking for? Morning Mike, Mark That picture is of a 6 terminal (sealed) Weather Pack connector. Those were heavily used in the auto industry years ago. You can find the Weather Pack connectors (6 terminal) including terminals at a number of auto parts stores, or on-line, like Amazon or E-Bay (Last I looked about $13.00 on Amazon. Those Weather Pack connectors are well sealed (but large for what they are), they work good & carry amperage well. The 2 big downsides to me personally are, the size, (not a big deal if size doesn't matter), & the disconnection trigger. The square edged little lock arm & the very sharp locking tit under it can take meat out of a finger or thumb if the connector is used for frequent disconnects. A glove will prevent the hurt or very carful use of the disconnect arm but it is something to keep in mind. The Weather Pack terminals (sealed or unsealed) do require a proper (re special) terminal crimp tool (not cheap) that folds the terminal ears in on the wire. If an incorrect crimping tool is used then the wire can eventually pull out of the terminals. They can be made to work with an incorrect crimping (cheap tool) if the terminal to wire interface is properly soldered. Personally I have pretty well switched over to using the sealed Deutsch DT 6 Pin for low amp usages like lighting or accessories as it is more compact. 1 Link to comment
Dingo55 Posted March 6, 2023 Author Share Posted March 6, 2023 Thanks DR The plug you mention is that a simple connect electrical wise ie special tools required ? There is no top box handle ? Correct? Cheers Mark Link to comment
Cap Posted March 7, 2023 Share Posted March 7, 2023 4 hours ago, Dingo55 said: Thanks DR The plug you mention is that a simple connect electrical wise ie special tools required ? Deutsch connectors are great. You can buy a kit on Amazon with several sizes and a bunch of male and female pins. You will need a terminal crimping tool. If you need to disassemble a connector, you will also need the correct size of pin remover. Again, a set of pin removers is cheap on Amazon. https://www.amazon.com/gp/product/B07VK35Q2D https://www.amazon.com/gp/product/B07V1C6N2V https://www.amazon.com/gp/product/B085W4PZLX Link to comment
MikeB60 Posted March 7, 2023 Share Posted March 7, 2023 On 3/6/2023 at 5:43 AM, wbw6cos said: On the 49 L topcase? Side cases do. Pictures? Not on the new one. I was thinking of the older 49L case.... 1 Link to comment
dirtrider Posted March 7, 2023 Share Posted March 7, 2023 19 hours ago, Dingo55 said: Thanks DR The plug you mention is that a simple connect electrical wise ie special tools required ? Afternoon Mark As far as easy or simple to connect? That depends, if a person is used to working with wire terminals & has the correct crimping tool then yes very easy to work with. Not very complicated & it CAN be done without a proper crimp tool (I didn't have a proper crimping tool at home when I started using the sealed Deutsch connectors but I do have a large assortment of various crimping pliers so I found something I had that would work). You just need a crimping tool that puts the indentation crimp in the terminal (shown in one of Cap's pictures). You can't use (don't want to use) a cheap common crimping tool that simply crushes the terminal on the wire). Link to comment
