2022RT rear strut preload (auto leveling) not responding
Limecreek
Limecreek
Has anyone experience a preload failure of the DESA rear strut?
The strut does not rise or fall regardless of the load I put on the bike and it is not responding to a change between Min and Auto.
I checked the log for error codes - nothing. And it appears the ZFE can see the suspension nodes.
I would assume if this was a mechanical failure of the servo motor, that an error code would be logged? So now I am thinking this could be a software issue?
Any thoughts?
Limecreek
2 hours ago, MikeB60 said:
If you have a GS911 you could try to run a suspension calibration.
Good suggestion. I ran a calibration and it completed successfully but the preload motor is still asleep.
  • 3 weeks later...
Limecreek
For those that care - software fixed the issue.
