Ran_Bush Posted February 23, 2023 Share Posted February 23, 2023 I'm trying to replace the clutch on my '05 R1200 ST and as many of you know, you have to take the damn bike apart to get to the clutch. I have the BMW Shop Manual, and it says that to take off the rear sub-frame, I have to remove Bolt 1, then tighten a "threaded pin" on each side, and then remove Bolts 2 and 3 to release the sub-frame. Then Bolt 4 is loosened. The pin is shown in the attached JPG. I can't find it, either on the bike or on the Max Parts fiche. Does anyone where the pin is hidden, or know the full part number? I can't find it using the six digit number in the JPG, I need more numbers. I also can't see it in the Max Parts fiche rear sub-frame parts list. TIA. Link to comment
dirtrider Posted February 23, 2023 Share Posted February 23, 2023 25 minutes ago, Ran_Bush said: I'm trying to replace the clutch on my '05 R1200 ST and as many of you know, you have to take the damn bike apart to get to the clutch. I have the BMW Shop Manual, and it says that to take off the rear sub-frame, I have to remove Bolt 1, then tighten a "threaded pin" on each side, and then remove Bolts 2 and 3 to release the sub-frame. Then Bolt 4 is loosened. The pin is shown in the attached JPG. I can't find it, either on the bike or on the Max Parts fiche. Does anyone where the pin is hidden, or know the full part number? I can't find it using the six digit number in the JPG, I need more numbers. I also can't see it in the Max Parts fiche rear sub-frame parts list. TIA. Evening, I am losing my power again so this will be quick_ That 465691 is a BMW special tool not a motorcycle part. It's hidden in the BMW special tools list. Link to comment
Ran_Bush Posted February 23, 2023 Author Share Posted February 23, 2023 > That 465691 is a BMW special tool Thank you sir! Stay warm and safe. Link to comment
