Avian Posted February 23, 2023 Share Posted February 23, 2023 Long story short. bmw dealer communications is primitive. bike sitting on jack they took out the tranny for me to pick up and rebuild, it takes half a day to do I just dont have the parts, bought a set on ebay seller not responding, found one local guy is out of town until april, mine is a 1997 gs1100. and I dont have more than couple days thank you!! Link to comment
dirtrider Posted February 23, 2023 Share Posted February 23, 2023 1 hour ago, Avian said: Long story short. bmw dealer communications is primitive. bike sitting on jack they took out the tranny for me to pick up and rebuild, it takes half a day to do I just dont have the parts, bought a set on ebay seller not responding, found one local guy is out of town until april, mine is a 1997 gs1100. and I dont have more than couple days thank you!! Evening Avian The problem with transmission internals is almost nobody strips a known good BMW M 97 transmission apart to sell the internal parts. They typically sell the transmission as a whole unit. You might look for a good used M 97 then either part it out & use what you need or just install the transmission as received. Link to comment
Avian Posted February 23, 2023 Author Share Posted February 23, 2023 I'll take a transmission too but the input shaft has to be inspected since the bearing wears against the gear. Found the shaft new. No gear no bearing. Going to crack it open today after work and see what's damaged Link to comment
Avian Posted February 23, 2023 Author Share Posted February 23, 2023 Found one from a 1995 r1100R that's an m94 should fit? Link to comment
dirtrider Posted February 23, 2023 Share Posted February 23, 2023 On 2/23/2023 at 11:18 AM, Avian said: Found one from a 1995 r1100R that's an m94 should fit? Afternoon Avian Yes, it should fit but a fairly high number of those M 94 transmissions had issues with jumping out of gear, or not staying engaged in gear, as the shift dog ears & the gear shifting ears were not back-cut. Personally I would wait for an M 97 to show up if you can wait. 1 Link to comment
Avian Posted February 23, 2023 Author Share Posted February 23, 2023 So opened the case. My input shaft has a wide apart spring. My transmission has a last 3rd letter as E being a m97. The 2nd picture on ebay is from a 1999 r1100gs but the spring is closed kind. Why are they different. Mine seem to be failed bearing the shaft is lose. Haven't taken it out yet. But I hope I can get away with a bearing replacement Link to comment
dirtrider Posted February 23, 2023 Share Posted February 23, 2023 On 2/23/2023 at 4:01 PM, Avian said: So opened the case. My input shaft has a wide apart spring. My transmission has a last 3rd letter as E being a m97. The 2nd picture on ebay is from a 1999 r1100gs but the spring is closed kind. Why are they different. Mine seem to be failed bearing the shaft is lose. Haven't taken it out yet. But I hope I can get away with a bearing replacement Afternoon Avian There were a couple of different input shaft configurations. The M 94 was different than the M-97 with the spring coil spacing different. (looks about like what your pictures show), So make sure that you are comparing M-97 to M-97 parts. Very late late 1966 used the M-97 but the earlier ones used the M-94. Otherwise, you are probably going to have to remove your input shaft then take a close look at it, the rear bearing might be missing the snap ring, or very possibly the rear bearing to gear contact area is worn enough to allow the spring to push rearward (common). Link to comment
Avian Posted February 23, 2023 Author Share Posted February 23, 2023 10 minutes ago, dirtrider said: Afternoon Avian You are probably going to have to remove your input shaft & take a close look at it, the rear bearing might be missing the snap ring, or the possibly the bearing to gear are worn enough to allow the spring to push rearward. My shaft bearing destroyed possibly case destroyed too Link to comment
dirtrider Posted February 23, 2023 Share Posted February 23, 2023 On 2/23/2023 at 4:27 PM, Avian said: My shaft bearing destroyed possibly case destroyed too Evening Avian Yes, you have BIG problems with that one, personally I wouldn't mess with that one. I would most likely just install a good used transmission. 1 Link to comment
dirtrider Posted February 23, 2023 Share Posted February 23, 2023 14 minutes ago, Avian said: Will this fit? Afternoon Avian Yes it should, but that is an RT transmission so make sure that the gearing is the same and it will work for you. My electric power has been cutting on & off all day & I have some darn big trees down across my private road so I have some immediate problems to deal with at the moment. Maybe tomorrow I can look things up for you but I'm pretty tied up until tomorrow. 1 Link to comment
Avian Posted February 23, 2023 Author Share Posted February 23, 2023 Sorry to hear longer gears I don't mind hate the short gears of gs. But on adv someone said it's a 100%. Good luck man that sounds like a lot on the plate Link to comment
Avian Posted February 24, 2023 Author Share Posted February 24, 2023 Got the m97 the input shaft has play 2mm each side is that normal? Link to comment
9Mary7 Posted February 25, 2023 Share Posted February 25, 2023 It has some spline wear but I would have no problem installing that and riding it anywhere...... my .02 and I'm sure others will chime in. 1 Link to comment
Avian Posted February 25, 2023 Author Share Posted February 25, 2023 My dad said the same after inspection. Thank you Link to comment
9Mary7 Posted February 25, 2023 Share Posted February 25, 2023 33 minutes ago, Avian said: My dad said the same after inspection. Thank you Sounds like something my son would say...... Link to comment
