Avian Posted February 16, 2023 Share Posted February 16, 2023 Long story short I rode my overhauled GS1100 too hard broke the transmission. Intermediate shaft and possibly more! haven't Cracked it open yet. Which year and model internals fit? R1150? R1100 RT R? Thank you. Link to comment
dirtrider Posted February 16, 2023 Share Posted February 16, 2023 9 hours ago, Avian said: Long story short I rode my overhauled GS1100 too hard broke the transmission. Intermediate shaft and possibly more! haven't Cracked it open yet. Which year and model internals fit? R1150? R1100 RT R? Thank you. Morning Avian None of the 1150 6 speed transmissions will work. Most of the later 1100RT & R will work but the early 1100 transmissions had "O" ring gear sets with undercut differences. If you want to swap parts around then match the transmission year as close as you can to what you have now. If you just want to install the entire transmission then the later the better. A number of parts will swap out between the M93, M94, & the M97 but a large number of parts can't be swapped out between the M93, M94, & the M97. There were basically 3 different transmissions used in the 1100, with 2 different transmission colors (silver or black). The M93 was used on the very early 1100 motorcycles. The M94 was used up into the early 1996 model year. The M97 was used from mid 1996 up to end or production. If you want to swap parts then match your replacement to your current transmission model. If you want to simply replace then look for the M97 as that had some decent improvements over the M93 & M94. Before totally tearing your transmission apart you might make sure that your drive shaft didn't fail as there is a rubber joint between the front & rear part of the drive shaft that can fail then you lose forward drive. Link to comment
Jim Moore Posted February 16, 2023 Share Posted February 16, 2023 Adding to that, the M97 was introduced in middle of the 1997 model year. To make sure you get an M97 you need to find a transmission from a 98 or 99 bike. Here is my R1100transmission R&R step-by-step. I never remember why I do things in this order, but I know that if I do it differently I normally have to go back and do it again. Oilhead R1100RS Transmission Removal 1. Strap Front Wheel 2. Loosen intake tubes and slide into airbox (Done at this time to make it easier to pull fuel lines out) 3. Remove tank a. Disconnect fuel lines b. Disconnect vent lines c. Unbolt front of tank d. Disconnect fuel electronic connector 4. Remove rear side fairings 5. Remove battery 6. Remove battery box bolts 7. Remove starter. 8. Disconnect electronics (neutral and gear indicator switches on left, ABS and rear brake light switches on right) 9. Loosen a. Pins (both sides) b. Subframe Bolts (8) c. Exhaust bolts d. Shock bolts e. Torque arm bolts 10.Remove rear caliper 11. Remove rear wheel 12. Remove left footrest 13. Remove right footrest (leave it hanging by caliper and ABS assembly) 14.Remove exhaust 15. Remove final drive (Unbolt pins and front of torque arm) 16.Remove swingarm 17. Reinstall right footrest (one bolt) 18. Drain transmission oil 19. Remove right-front seat post 20. Remove rear shock 21. Remove airbox bolts (two in front, one in air filter housing) 22. Strap rear subframe 23. Remove subframe bolts (4) 24. Loosen subframe through-bolt 25. Ensure ABS lines are disconnected from rear subframe 26. Lift subframe 27. Unbolt injectors at throttle bodies 28.Remove airbox 29. Remove right footrest and leave it hanging 30. Unbolt bottom-right and top-left transmission bolts. 31. Install pins 32. Unbolt other transmission bolts 33. Slide transmission back. Use crowbar to hold battery box up so posts clear. 34. Locate clutch pushrod Installation 35. Insert pushrod 36. Install transmission (22 nm) 37. Reattach ABS lines to transmission 38. Adjust clutch if necessary 39. Install battery box nuts 40. Seat airbox 41. Attach engine breather. It goes BELOW the throttle cable. 42.Install driveshaft. 43. Lower subframe (watch electrical connectors) and install bolts (47 nm: Right-rear, right-front, left-front, left-rear) 44. Tighten through-bolt. 47 nm. 45. Install airbox bolts 46.Attach injectors 47.Install air filter and airbox lid. 48.Install shock (43 nm top and bottom) Do not tighten. 49. Install swingarm. (Pins are 100 ft-lb) on right side, 12 nm on left side, lock nut is damn tight) 50. Tighten shock (43 nm) 51. Install final drive (Pins are 100 ft-lb) on right side, 12 nm on left side, lock nut is damn tight) 52. Install torque arm (43 nm) 53.Install Starter 54. Install foot rests (22 nm) 55. Install Exhaust (20 ft-lb in back. 50 nm at the joint) 56. Reconnect electronics 57.Install rear wheel (77 ft-lb) 58. Install rear caliper (40 nm) 59. Install battery 60. Install fuel tank 61. Install panels 1 Link to comment
Avian Posted February 16, 2023 Author Share Posted February 16, 2023 9 hours ago, dirtrider said: Morning Avian None of the 1150 6 speed transmissions will work. Most of the later 1100RT & R will work but the early 1100 transmissions had "O" ring gear sets with undercut differences. If you want to swap parts around then match the transmission year as close as you can to what you have now. If you just want to install the entire transmission then the later the better. A number of parts will swap out between the M93, M94, & the M97 but a large number of parts can't be swapped out between the M93, M94, & the M97. There were basically 3 different transmissions used in the 1100, with 2 different transmission colors (silver or black). The M93 was used on the very early 1100 motorcycles. The M94 was used up into the early 1996 model year. The M97 was used from mid 1996 up to end or production. If you want to swap parts then match your replacement to your current transmission model. If you want to simply replace then look for the M97 as that had some decent improvements over the M93 & M94. Before totally tearing your transmission apart you might make sure that your drive shaft didn't fail as there is a rubber joint between the front & rear part of the drive shaft that can fail then you lose forward drive. Hi thank you. Mine is 97 so I think its m97. Drive shaft is new. It's 100% the transmission intermediate shaft. Link to comment
Avian Posted February 16, 2023 Author Share Posted February 16, 2023 8 hours ago, Jim Moore said: Adding to that, the M97 was introduced in middle of the 1997 model year. To make sure you get an M97 you need to find a transmission from a 98 or 99 bike. Here is my R1100transmission R&R step-by-step. I never remember why I do things in this order, but I know that if I do it differently I normally have to go back and do it again. Oilhead R1100RS Transmission Removal 1. Strap Front Wheel 2. Loosen intake tubes and slide into airbox (Done at this time to make it easier to pull fuel lines out) 3. Remove tank a. Disconnect fuel lines b. Disconnect vent lines c. Unbolt front of tank d. Disconnect fuel electronic connector 4. Remove rear side fairings 5. Remove battery 6. Remove battery box bolts 7. Remove starter. 8. Disconnect electronics (neutral and gear indicator switches on left, ABS and rear brake light switches on right) 9. Loosen a. Pins (both sides) b. Subframe Bolts (8) c. Exhaust bolts d. Shock bolts e. Torque arm bolts 10.Remove rear caliper 11. Remove rear wheel 12. Remove left footrest 13. Remove right footrest (leave it hanging by caliper and ABS assembly) 14.Remove exhaust 15. Remove final drive (Unbolt pins and front of torque arm) 16.Remove swingarm 17. Reinstall right footrest (one bolt) 18. Drain transmission oil 19. Remove right-front seat post 20. Remove rear shock 21. Remove airbox bolts (two in front, one in air filter housing) 22. Strap rear subframe 23. Remove subframe bolts (4) 24. Loosen subframe through-bolt 25. Ensure ABS lines are disconnected from rear subframe 26. Lift subframe 27. Unbolt injectors at throttle bodies 28.Remove airbox 29. Remove right footrest and leave it hanging 30. Unbolt bottom-right and top-left transmission bolts. 31. Install pins 32. Unbolt other transmission bolts 33. Slide transmission back. Use crowbar to hold battery box up so posts clear. 34. Locate clutch pushrod Installation 35. Insert pushrod 36. Install transmission (22 nm) 37. Reattach ABS lines to transmission 38. Adjust clutch if necessary 39. Install battery box nuts 40. Seat airbox 41. Attach engine breather. It goes BELOW the throttle cable. 42.Install driveshaft. 43. Lower subframe (watch electrical connectors) and install bolts (47 nm: Right-rear, right-front, left-front, left-rear) 44. Tighten through-bolt. 47 nm. 45. Install airbox bolts 46.Attach injectors 47.Install air filter and airbox lid. 48.Install shock (43 nm top and bottom) Do not tighten. 49. Install swingarm. (Pins are 100 ft-lb) on right side, 12 nm on left side, lock nut is damn tight) 50. Tighten shock (43 nm) 51. Install final drive (Pins are 100 ft-lb) on right side, 12 nm on left side, lock nut is damn tight) 52. Install torque arm (43 nm) 53.Install Starter 54. Install foot rests (22 nm) 55. Install Exhaust (20 ft-lb in back. 50 nm at the joint) 56. Reconnect electronics 57.Install rear wheel (77 ft-lb) 58. Install rear caliper (40 nm) 59. Install battery 60. Install fuel tank 61. Install panels Appreciate you. Found a 1998 R1100RT trans for cheap all gears in good shape 👍 Link to comment
dirtrider Posted February 16, 2023 Share Posted February 16, 2023 21 minutes ago, Avian said: Hi thank you. Mine is 97 so I think its m97. Drive shaft is new. It's 100% the transmission intermediate shaft. Afternoon Avian Yes, your 1997 should have the M 97 as the M97 was phased into production about April or May of 1996 (just slightly before 1997 production began). The usual problem with the M97 is the rear bearing to gear contact then resulting wear. (check your PM messages on this site as I sent your some info on that) Link to comment
Avian Posted February 16, 2023 Author Share Posted February 16, 2023 37 minutes ago, dirtrider said: Afternoon Avian Yes, your 1997 should have the M 97 as the M97 was phased into production about April or May of 1996 (just slightly before 1997 production began). The usual problem with the M97 is the rear bearing to gear contact then resulting wear. (check your PM messages on this site as I sent your some info on that) Thank you sir 9 hours ago, Jim Moore said: Adding to that, the M97 was introduced in middle of the 1997 model year. To make sure you get an M97 you need to find a transmission from a 98 or 99 bike. Here is my R1100transmission R&R step-by-step. I never remember why I do things in this order, but I know that if I do it differently I normally have to go back and do it again. Oilhead R1100RS Transmission Removal 1. Strap Front Wheel 2. Loosen intake tubes and slide into airbox (Done at this time to make it easier to pull fuel lines out) 3. Remove tank a. Disconnect fuel lines b. Disconnect vent lines c. Unbolt front of tank d. Disconnect fuel electronic connector 4. Remove rear side fairings 5. Remove battery 6. Remove battery box bolts 7. Remove starter. 8. Disconnect electronics (neutral and gear indicator switches on left, ABS and rear brake light switches on right) 9. Loosen a. Pins (both sides) b. Subframe Bolts (8) c. Exhaust bolts d. Shock bolts e. Torque arm bolts 10.Remove rear caliper 11. Remove rear wheel 12. Remove left footrest 13. Remove right footrest (leave it hanging by caliper and ABS assembly) 14.Remove exhaust 15. Remove final drive (Unbolt pins and front of torque arm) 16.Remove swingarm 17. Reinstall right footrest (one bolt) 18. Drain transmission oil 19. Remove right-front seat post 20. Remove rear shock 21. Remove airbox bolts (two in front, one in air filter housing) 22. Strap rear subframe 23. Remove subframe bolts (4) 24. Loosen subframe through-bolt 25. Ensure ABS lines are disconnected from rear subframe 26. Lift subframe 27. Unbolt injectors at throttle bodies 28.Remove airbox 29. Remove right footrest and leave it hanging 30. Unbolt bottom-right and top-left transmission bolts. 31. Install pins 32. Unbolt other transmission bolts 33. Slide transmission back. Use crowbar to hold battery box up so posts clear. 34. Locate clutch pushrod Installation 35. Insert pushrod 36. Install transmission (22 nm) 37. Reattach ABS lines to transmission 38. Adjust clutch if necessary 39. Install battery box nuts 40. Seat airbox 41. Attach engine breather. It goes BELOW the throttle cable. 42.Install driveshaft. 43. Lower subframe (watch electrical connectors) and install bolts (47 nm: Right-rear, right-front, left-front, left-rear) 44. Tighten through-bolt. 47 nm. 45. Install airbox bolts 46.Attach injectors 47.Install air filter and airbox lid. 48.Install shock (43 nm top and bottom) Do not tighten. 49. Install swingarm. (Pins are 100 ft-lb) on right side, 12 nm on left side, lock nut is damn tight) 50. Tighten shock (43 nm) 51. Install final drive (Pins are 100 ft-lb) on right side, 12 nm on left side, lock nut is damn tight) 52. Install torque arm (43 nm) 53.Install Starter 54. Install foot rests (22 nm) 55. Install Exhaust (20 ft-lb in back. 50 nm at the joint) 56. Reconnect electronics 57.Install rear wheel (77 ft-lb) 58. Install rear caliper (40 nm) 59. Install battery 60. Install fuel tank 61. Install panels Appreciate you. Found a 1998 R1100RT trans for cheap all gears in good shape 👍 Link to comment
