Woodchips Posted January 19, 2023 Share Posted January 19, 2023 I recently purchased a 06 RT 1200 without a trunk but was able to locate a mint 49 litre one with a key. I went to the local BMW dealer and was advised that I could order a new Cylinder ($86Cdn.) and they would key it to my existing key. When he looked up the part number it indicated that the cylinder was no longer available from BMW. He then suggested that i go online and see what others have done to solve the issue. While carrying a separate key is not a big problem, it would be nice to have the trunk open with the same key as the saddle bags. Suggestions? Ron Link to comment
KDeline Posted January 20, 2023 Share Posted January 20, 2023 I took the easy cheap way and just removed all but the bottom tumbler. That holds the lock barrel in place. The problem doing it this way, it will turn with any key or small screw driver but if you don't tell anyone............ 1 Link to comment
GordonB Posted January 20, 2023 Share Posted January 20, 2023 My dealer simply re-keyed the existing cylinder to match my original key. Any other dealers nearby? Link to comment
Woodchips Posted January 22, 2023 Author Share Posted January 22, 2023 Not any “authorized” dealers, a couple of BMW “specialists” but no help from them. Link to comment
Mike279 Posted January 22, 2023 Share Posted January 22, 2023 https://youtu.be/vlppCcPogfs This link shows a possible way to remove a lock cylinder. My trunk cylinder did not come out with the pick tool. Link to comment
Woodchips Posted January 22, 2023 Author Share Posted January 22, 2023 Thanks Mike Interesting, If I try that method I’ll take the cylinder to either the BMW dealer or preferably a locksmith for rekeying. Ron Link to comment
Mike279 Posted January 22, 2023 Share Posted January 22, 2023 Watch a couple of rekeying videos and you can do it yourself. The wafers and small springs are not hard to reconfigure to an existing key. Another good video https://www.youtube.com/watch?v=mygeTPWUhqY Link to comment
Tri750 Posted February 9, 2023 Share Posted February 9, 2023 Did you get the trunk figured out ? I sell a lock cylinder removal tool, included is tech help to do it and info on rekeying . text or call 559-288-1490 Link to comment
Woodchips Posted February 9, 2023 Author Share Posted February 9, 2023 Not yet, a couple of other priorities keep getting in my way😔. Ill post when I get it sorted. 🛵 1 Link to comment
szurszewski Posted February 10, 2023 Share Posted February 10, 2023 On 1/22/2023 at 11:57 AM, Woodchips said: Thanks Mike Interesting, If I try that method I’ll take the cylinder to either the BMW dealer or preferably a locksmith for rekeying. Ron 15 hours ago, Woodchips said: Not yet, a couple of other priorities keep getting in my way😔. Ill post when I get it sorted. 🛵 If you can get the cylinder out, there is no reason to take it to someone for "rekeying". It's not hard to get the cylinder out (not sure what tool Tri750 sells or how much, but I suspect it makes it even easier) and once that's done, moving the wafers around to match your key is no big deal at all. 1 Link to comment
bruce2000ltc Posted February 10, 2023 Share Posted February 10, 2023 I agree with szurszewski. Once you get the cylinder out it's not hard to rekey and you don't need to use all the wafers for it to work. You just need to match a couple of the wafers to your key and it will work fine. That's what I did on mine. 1 Link to comment
Tri750 Posted February 10, 2023 Share Posted February 10, 2023 17 hours ago, Woodchips said: Not yet, a couple of other priorities keep getting in my way😔. Ill post when I get it sorted. 🛵 When you get around to it , save my number and I’d be happy to help you out . here’s a link to a removal video on that exact case . Al 559-288-1490 1 Link to comment
TSConver Posted February 10, 2023 Share Posted February 10, 2023 36 minutes ago, Tri750 said: When you get around to it , save my number and I’d be happy to help you out . here’s a link to a removal video on that exact case . Al 559-288-1490 Great video showing thieves how to pop our locks. 1 Link to comment
Tri750 Posted February 10, 2023 Share Posted February 10, 2023 4 minutes ago, TSConver said: Great video showing thieves how to pop our locks. All “they” need is to spend $35 for the tool and have 15-25 minutes to figure out how to use it . Then “they” have to release or open the case with another tool. I’ve done it for 15 years or starting at a bmw dealership so I tend to do it a bit faster . realiy, there are faster ways to steal your beef jerky and dirty underwear by taking the whole case in seconds . No, I won’t tell about that . 2 Link to comment
Lowndes Posted February 10, 2023 Share Posted February 10, 2023 I made a "tool" from a "gem clip". Do you have a pair of pliars, a gem clip, and can count to six?? If YES, you are hereby QUALIFIED. There are seven "sliders"with springs. The bottom one is the "keeper" that keeps the cylinder in the lock. When you slide it over with the "tool" the cylinder slides right out. The arrow points to the "keeper slider". This is the "keeper" slider: When you push it over (like this) with the pointy end of the "tool", the cylinder will slide up and out. Don't worry about the other sliders. This is a sharpie mark at 22.5mm so I'll know how deep to go. You can feel the slider with the end of the "tool", push it sideways and gently pull up. If it won't come out you either aren't "on" the slider or pushed it too far or not far enough. Once you get it out it's not hard to re-key it yourself. This is what the cylinder looks like with the correct key in it. All the sliders are flush on both sides (except for the keeper at the bottom) which allows the cylinder to rotate and unlock your beer. This is what the cylinder looks like with NO key: This key "code" is 221122. "H" is the keeper, "G" not used. The sliders will readily come out alternating sides and can be swapped all around, OR left out completely (as szurszewski said above) CAUTION: there is a tiny spring pushing each slider (and the keeper) in these holes. If your lockset is VERY CLEAN like this one is, that spring can launch the slider as you pull the cylinder out. ALL the pics here: https://photos.app.goo.gl/38jzUkW9spfCmnF77 Link to comment
Tri750 Posted February 11, 2023 Share Posted February 11, 2023 Sadly , none of all your posting applies to the System 2 locks . Or most of the 1150 locks either . The lock wafer was updated before the 1150 came out to a 3 sided wafer intentionally making removal much more difficult . the System 2 cases (laser cut/side cut) with the internals being mainly plastic just made removal harder . 1 Link to comment
