lather Posted January 19, 2023 Share Posted January 19, 2023 I ran over a big board at speed today and bent my front wheel badly. Luckily stayed upright and no air lost. I am searching for a used wheel and from various listings it seems that R200 RT R and RS from 2005 through 2013 are all compatible with my 2013 US R1200RT. Can anyone confirm this? Thanks Link to comment
lather Posted January 19, 2023 Author Share Posted January 19, 2023 Another questio: Why is there a bolt here? Link to comment
dirtrider Posted January 19, 2023 Share Posted January 19, 2023 8 minutes ago, lather said: Another questio: Why is there a bolt here? Evening lather That is for mounting the tire pressure sensor (TPS sensor). Link to comment
John Ranalletta Posted January 19, 2023 Share Posted January 19, 2023 59 minutes ago, lather said: I ran over a big board at speed today and bent my front wheel badly. Luckily stayed upright and no air lost. I am searching for a used wheel and from various listings it seems that R200 RT R and RS from 2005 through 2013 are all compatible with my 2013 US R1200RT. Can anyone confirm this? Thanks They appear to be interchangeable. Confirm before buying. Hope insurance co. is on the hook. 2010-2013 #36 31 7 696 159 2003-2009 #36 31 7 696 159 https://shop.maxbmw.com/fiche/DiagramsMain.aspx?vid=52026&rnd=09082020 Link to comment
lather Posted January 19, 2023 Author Share Posted January 19, 2023 Thanks for the reply. I was looking at Max BMW just now as well. Drawings on the two diagrams look different to me but it seems the wheels are the same. Photos of spacers and seals look the same. I see a decent option on an 09 on ebay. The tricky part with confirming compatibility is years are different from Europe to the US. Link to comment
9Mary7 Posted January 20, 2023 Share Posted January 20, 2023 2009 wheel is the same US or UK. Link to comment
lather Posted January 20, 2023 Author Share Posted January 20, 2023 15 hours ago, dirtrider said: Evening lather That is for mounting the tire pressure sensor (TPS sensor). Morning dirtrider. Thanks for the reply. Link to comment
lather Posted January 20, 2023 Author Share Posted January 20, 2023 9 hours ago, 9Mary7 said: 2009 wheel is the same US or UK. Thanks for the reply 9Mary7 Link to comment
dirtrider Posted January 20, 2023 Share Posted January 20, 2023 57 minutes ago, lather said: Morning dirtrider. Thanks for the reply. Morning lather I'm not sure if this still applies but if your motorcycle came with TPMS (Tire Pressure Monitoring) you might need to make sure that the wheel you are planning on buying is a TPMS wheel. Back in the Hexhead time frame BMW used a different wheel for no TMPS & with TPMS so a standard wheel wouldn't work on a TPMS motorcycle. But just to confuse (actually to reduce the number of wheels BMW needed to keep in stock) they serviced the non TPMS wheel using the TPMS wheel (TPMS wheel will work on a no-TPS motorcycle but not the other way around. Problem is, a lot of sellers just use the parts book listing & cross-reference numbers to list their wheels. So according to the parts book the wheels are the same for both TPMS & non TPMS motorcycles. So bottom line, if your motorcycle has TPMS then verify it is a TPMS wheel that you are buying. If you don't have TPMS then it doesn't matter. Link to comment
lather Posted January 20, 2023 Author Share Posted January 20, 2023 Morning dirtrider. Yes I have TPMS. I purchased the wheel that I pictured in my post asking about the bolt. Also, I was able to see the sensor position sticker on an additional photo displayed by the sellor. Thanks again! Link to comment
