Stavros Posted December 11, 2022 Share Posted December 11, 2022 Hello! Recently I took a 400 miles ride at a relatively high speed on my 2003 R1150rt. (Had to be somewhere in time). On the highway, the plastic cover of the spark plug, (already damaged by the previous owner), was "kicked" away by the wind and got "secured" between my left boot and the bike. The bike run beautiful all the way long without the slightest hesitation. When I stopped 300 miles afterwards and inspected the cylinder head, I realised that the plastic cover had pulled together the little wire from the spark plug. I pushed the wire back to the fiche and threw away the cover, (I already replaced it with a new one). Am I fool to think that I might did all these miles on one cylinder? Was the secondry spark plug sufficient for the trip? Is there a chance I caused any damage? The Boxer runs perfectly so far. Thank you! Link to comment
dirtrider Posted December 11, 2022 Share Posted December 11, 2022 50 minutes ago, Stavros said: Hello! Recently I took a 400 miles ride at a relatively high speed on my 2003 R1150rt. (Had to be somewhere in time). On the highway, the plastic cover of the spark plug, (already damaged by the previous owner), was "kicked" away by the wind and got "secured" between my left boot and the bike. The bike run beautiful all the way long without the slightest hesitation. When I stopped 300 miles afterwards and inspected the cylinder head, I realised that the plastic cover had pulled together the little wire from the spark plug. I pushed the wire back to the fiche and threw away the cover, (I already replaced it with a new one). Am I fool to think that I might did all these miles on one cylinder? Was the secondry spark plug sufficient for the trip? Is there a chance I caused any damage? The Boxer runs perfectly so far. Thank you! Afternoon Stavros Not the best idea to run the 1150 at high speed with just the lower plugs working as the ignition advance curve is based on both plugs working. But if it ran OK & you didn't hear any spark knocking or pinging then I doubt it did any damage. 1 Link to comment
Stavros Posted December 13, 2022 Author Share Posted December 13, 2022 On 12/11/2022 at 11:09 PM, dirtrider said: Afternoon Stavros Not the best idea to run the 1150 at high speed with just the lower plugs working as the ignition advance curve is based on both plugs working. But if it ran OK & you didn't hear any spark knocking or pinging then I doubt it did any damage. Thank you dirtrider! I would hate to be the one to "sank" the Titanic...not in my watch! Link to comment
