Boulder Dave Posted December 11, 2022 Share Posted December 11, 2022 First off it has what I believe to be an electrical gremlin. Bike runs fine then it stops without warning. Bike sits overnight and will start again. Runs for 30 minutes to several days and dies again. Yes, I’ve replaced the HES. I consider myself a solid mechanic and I’m stumped. Could be a chaffed wire or something more. Dunno. Can’t find a smoking gun. Have title and bike is on non-op registration.Cosmetically it’s a 9.5. Mechanically, everything works (the stalling issue aside). I have owned or maintained the bike for 10 years. About four of those years, a friend had the bike, but I still did the maintenance. Servo brakes flushed regularly and steel brake hoses fitted nine years ago.Bike has approx. 70k on it. I swapped odometer because of a broken needle. I have the old odo and the mileage of the new odo when I installed it.Bike is located in Sacramento. Asking $1,200Help my mental state and help me get some room back in the garage. Link to comment
danielshuck Posted December 23, 2022 Share Posted December 23, 2022 Would you sell the panniers? Link to comment
RK Ryder Posted December 26, 2022 Share Posted December 26, 2022 Could your problem be faulty wiring to the side stand switch? I had a similar problem several years ago with my ‘98 R1100RT that did not clear up with a new HES. The culprit was worn side stand wires. With new wiring to the side stand switch the problem never reoccurred. Link to comment
szurszewski Posted December 27, 2022 Share Posted December 27, 2022 On 12/26/2022 at 6:42 AM, RK Ryder said: Could your problem be faulty wiring to the side stand switch? I had a similar problem several years ago with my ‘98 R1100RT that did not clear up with a new HES. The culprit was worn side stand wires. With new wiring to the side stand switch the problem never reoccurred. This is also listed on ADV - and the poster of that thread listed this: Things I’ve done:New battNew HESNew coil/wiresNew fuel pump and internal fuel hosesConfirmed fuel flowConfirmed sparkConfirmed injectors functioningManipulated ignition and headstock area wiring Link to comment
